Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Help please cdti 150
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Default Help please cdti 150
    My cdti is suffering from a few problems
    1. It seems to have developed a problem, upon start up, even in warm weather it is lumpy and noisy. Then when warm it seems fine. It wasnt like this previously. I also have EML comes on upon start up then goes after 5 minutes of driving. I have had DMF/clutch replaced about 8 months ago, also I have been told my inlet manifold needs replacing as one of the rods has dropped off.
    2. I also have a hesitation (like it's about to run out of fuel) always at 1800rpm in any gear.
    3. Lastly I have a strange noise that seems to come from the p/s rear sounds to me like a metallic banging, only over uneven roads. I had springs replaced earlier this year and front arb/droplink
    Could anyone help please
    West
    1. eml on for a couple of mins after starting could be the glow plugs, although they're not actually needed at this time of year...
    2. the hesitation could be egr related, try unplugging it before starting & take it for a run, if it's improved then either clean replace or blank off.
    3. this knock could be a failing shocker or a rear upper control arm.
    hth
    Jul 2010
    Skipton
    hth
    Excellent thanks for the quick response.
    Are all of the above reasonably cheap to have remedied? I seriously am not mechanically gifted so would be looking at the dealers for it doing or local mechanic (although he doesnt seem cheap nowadays)
    Where is the egr?
    Regular Member coooky's Avatar
    May 2011
    washington
    inlet manifold £160 plus £8 p&p on e-bay cost to fit unsure its a large job from what im read to believe
    egr blank off plate £3 from e-bay
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    May 2011
    washington
    Quote Originally Posted by ONEMINUTESILENCE View Post
    Where is the egr?
    look at the engine its at the top right
    look at the pic here and also this is the blanking plate
    http://cgi.ebay.co.uk/EGR-Blanking-P...item35b36e8b04
    Sep 2010
    in a box
    mate link above show you were it is
    Jul 2010
    Skipton
    Quote Originally Posted by coooky View Post
    Is it safe to blank off permenantly?
    May 2011
    washington
    yes done mine the other day you might get the EML pop up but if you do drill a small 9mm hole in the middle to let a few gases through
    going to get my egr took out when i get it remapped
    Sep 2010
    in a box
    ^^it will throw up a light if i member right
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
