Thread: Engine Management Light came on, no apparent turbo afterwards..?
    Regular Member Buzzby's Avatar
    Jul 2010
    Staffs
    Default Engine Management Light came on, no apparent turbo afterwards..?
    Hi, I have an 05 Plate 1.9 Signum DTI. I was driving home tonight, and felt a loss of power whilst on a dual carriageway. Engine management light came on (Spanner over car??), car ticked along steadily at 70-80, but was lacking the guts of normal. Pulled off and onto a side road, and when moving up the gears, there was a real lack of surge around the rev range where the turbo usually kicks in, if anything the power distinctly died off...
    Any ideas what this could be. I know there are hundreds of options, but from anyone's experience, are we talking major issue potentially with the turbo, or maybe something less like a hose or sensor that has gone??
    Still drived fine and has usual power up until turbo range, but definite lack of turbo kicking in then.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check all the vac pipes mate.
    Jul 2010
    Staffs
    Cheers, Just tried to run it again, and all went smoothly, turbo kicked in as expected....
    West
    get the codes read... other wise it's just guesswork
    Bristol
    When the eml light comes on , if its a serious fault the ecu shuts down all actuators and goes into limp mode, thats why you lost the turbo.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. Engine Management light on 2.8 turbo.
    By Largespanners in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:50
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
