Results 1 to 10 of 18
Thread: 2L DTI '53 Loss of Power
    Apr 2006
    york
    Default 2L DTI '53 Loss of Power
    Hi folks,
    I have an intermittent problem.
    After my car has been running for about an hour, the spanner light comes on and I have no/little acceleration - which can be a bit embarrassing when trying to overtake in the outside lane of the motorway!!
    The engine management light does not come on - pulling over to the hard shoulder and turning the engine off/on sometimes clears the problem.
    I have briefly checked the hoses from the turbo for leaks.
    Any ideas? - dont want to take it to the stealers!!
    West
    start by checking around the vac system - all the little tubes & connectors, any tiny splits will cause the spanner
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    As well as the small vacuum hose check you may also need to clean the boost sensor
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Give the MAF sensor a clean also
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by CritchvxD View Post
    sorry to hi jack how do you clean the MAF
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Unplug it an remove from air intake. An spray with carb cleaner allow to dry naturally
    Oct 2009
    Sandwell
    hurd carb cleaner can kill these tho am i wrong?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Not sure tbh mate. I've not heard it.
    I'm sure it would be fine.
    Surpose you could always try electrical contact cleaner. As it's probably about the same price
    north east
    to clean the maf hold the sensor at least arm length away from the spray or soak it in meths ;-)
    odds on bet in a few weeks they op will need a crank shaft speed sensor, to test this theory once the car is upto running temp on your private road try hold the speed at 80 mph if the light comes on before you reach 80 ill put 50p on it being the crank shaft sensor on its way out.
    Apr 2006
    york
    have checked the vac pipes and all ok - where is the boost sensor?
    also removed and cleaned the egr - it was pretty coked up - so cleaned it.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
  5. Power Loss 2.0T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 30th April 2009, 23:13
