Thread: CID, Outside air temp
    Jul 2011
    Elgin
    Default CID, Outside air temp
    My outside air temp on the clock screen reads _ _._*C. Any ideas what that fault may be?
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Faulty sensor? (behind lower front grill)
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Northern Ireland Region trip to Knockhill 2014
    Jul 2011
    Elgin
    Put a new sensor in bout a month ago and still reads _ _._*C
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you had a new bumper fitted?
    Came across this a while back, where the donor bumper still had a length of it's loom attached.
    After removing the "donor" loom, and fitting the car's own loom to the bumper, full service was restored.
    A faulty sensor would normally give a stupidly high value, such as 43'C.
    --.-'C means that there is an open circuit to the sensor.
    If you are on your original bumper and loom, then I would check for a broken wire.
    Note the wires are blue and blue/white.
    These run from the sensor, direct to the body control module behind the glove box.
    Pins numbered 44 and 47 if my memory serves me well.
    If you cannot find the break in the wire, try putting in two flying leads direct to the BCM as described.
    If this now works, then put in two permanent replacement wires.
  1. temp
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 19th January 2013, 19:44
  2. What's your temp at?
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 22:14
  3. What temp should air con be ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:49
  4. DTI temp
    Last Post: 23rd September 2010, 22:53
  5. outside air temp
    By leeashford in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 19:34
