Thread: Extra Functions
    Jul 2011
    Elgin
    confused Extra Functions
    Evening all.
    Someone told me that pretty much all Vec's come with all the fuctions i.e. seatbelt warning, front foglight addition, buit in sat, etc. They just arent programmed into the cars computer. Is this true? and what functions can I bring to life?
    If you havent guessed already, I'm a complete novice when cars are concerned
    Cheers guys
    Jul 2011
    Elgin
    Default Oh Yeah
    Mines the 2005 Vectra C, LS
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Hi ken and welcome to the site
    Not sure which ones will be available to you but there is some intersting reading in this thread:-
    http://www.vectra-c.com/forum/showthread.php?t=86965
    Not all the functions work with every car but will give you some idea what to try out and look for
    Hope it helps
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Full Member Robsey's Avatar
    North East Cheshire
    17 Post(s)
    Trim : Energy
    Mileage : 131,000
    It all depends on your vehicles specification..and the year of manufacture.
    Many items need to be modified by inserting extra wiring, others can be simply programmed via Tech 2 or Op-Com.
    Some require complete modules to be changed.. usually CIM modules or UEC modules.
    CIM = Collumn Integrated Module ( Wrapped around the steering collumn behind the airbag squib. Responsible for anything to do with steering wheel controls and stop / start ignition key status, Airbag and links to other modules.
    UEC = Under Hood Electrical Centre - electrical centre underneath the main engine fuse / relay box. Responsible for warning signals (Low fluids and brake pad wear), lighting control, fuel level sensor connection, wipers etc..
    More to the point - what "extras" do you wish to fit / enable.?
  1. BC Functions
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 10:18
  2. CD70 display & functions
    By RayR33 in forum Electrical & ICE (including SatNav)
    Last Post: 29th October 2009, 10:29
  3. Possible to extend functions on a Eberspächer?
    By fikse in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2009, 21:11
  4. lost multifunction button functions
    By BESTuning in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 19:56
