Results 1 to 10 of 13
Thread: Tyre width
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Tyre width
    hi guys can i put 225/45/17 on the front and have 215/50/17 on the rear? also will it pass the mot like it? Thanks
    Regular Member Marcosuk's Avatar
    Fife
    Would look better with the wider tyre on the rear
    Im sure you can do that, but someone will clarify..
    Presumably the 215/50R17 is older and the 225/45R17 is newer
    Put the 215/50R17 on the front, that way it will wear out first, then you can have 225/45R17 across both axles
    There are no issues about different tyre sizes, so long as they are consistent across the car
    May 2007
    Norwich
    Engine : 2.2 z22se
    I thought it would be ok, i need two new ones on the front for the mot but the rears are mis-matched brands and i cant afford to get all four at once as im going on hols in 3weeks.
    Engine : 1.9 CDTi
    It will be fine.
    You need to have the same on the same axle.
    Cheshire
    It is generally considered dangerous to have the narrower tyres on the rear!! all other things being equal the narrower tyre will give less grip!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by lee gsi View Post
    It will be fine.
    You'd either have to carry two spares, one of each size, or stick with the space saver spare.
    11 Post(s)
    Quote Originally Posted by paul667 View Post
    I ran with 225's on the front and 215/s on the rear for approx 2 years with no problems whatsoever.
    Besides which, you're talking about a few mm difference, not a massive amount of width difference.
    Please provide a link to such evidence from a tyre manufacturer
    The 215/50R17 and 225/45R17 have the same surface area on the road, so I don't see how this can be considered dangerous
    Equally, if it was an issue then there would be a restriction on using such different tyres
    May 2007
    Norwich
    Engine : 2.2 z22se
    Cheers lads i thought i would be ok just wanted to check!!
  1. tyre width
    By SarahP in forum Suspension, Wheels & Brakes
    Last Post: 3rd June 2012, 19:18
  2. tyre width advise please
    By gavs-sri in forum Handling & Braking
    Last Post: 6th April 2012, 17:39
  3. Maximum Tyre Width
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2010, 17:59
  4. Tyre Width Table
    By Caterman in forum Handling & Braking
    Last Post: 21st February 2009, 23:07
  5. tyre width
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 16:59
