Results 1 to 10 of 13
Thread: p0400-5a fault code
    Jan 2010
    cornwall
    Default p0400-5a fault code
    P0400-5a fault code. Recirculating exhaust gas flow ? Any ideas people?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by swvectra View Post
    EGR valve faulty?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Egr, clean the egr as per the 'how 2' section, also clean the boost sensor & the throttle body wouldn't go a miss also, all of the how 2's are easy to follow & need no special skills.
    Jan 2010
    cornwall
    What's the best thing to use to clean them?
    Engine : 1.9 CDTi
    I just used carb cleaner.
    Nov 2010
    East Midlands
    Trim : design
    Most use carburettor cleaner - I did mine with oven cleaner and left it over night before cleaning off with stiff brush
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    oven cleaner is very corrosive on aluminium.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Al 22 dti View Post
    Not according to the label on the tin it isn't - but make sure you rinse it off properly - good for cleaning alloy wheels as well!
    Jun 2011
    Elland
    Depends what's in it - if it's caustic (sodium hydroxide), then it attacks aluminium violently. The newer ones are polycarboxylate based and are very good. Try it on something that doesn't matter first. Some dishwasher tablets are polycarboxylate based, so you might have some lying around in your home already!
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by hebblemarine View Post
    Hi, Thanks for that - I've just had a look on the tin and it does contain polycarboxylate and says suitable for aluminium finishes - experimented on an old aluminium brake caliper before cleaning the EGR and left it for 2 days before rinsing off with no ill effects. If you consider that oven cleaner removes that baked on stuff in your oven - cleaning the carbon from an EGR valve is a piece of cake. And its relatively cheaper than anything else - got mine from the pound shop.
  1. Keep getting trouble code: P0400-5A, on SRI CDTI 150
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 18th January 2013, 19:38
  2. P0400-f8 fault code
    By leeeager in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 13:08
  3. P0400 Fault code help needed PLease.
    By Nick1 in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  4. Error code p0400, EGR help.
    By Rainbow6six in forum Engine & Drivetrain
    Last Post: 21st July 2010, 10:07
  5. Error code: P0400 - EGR
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 3rd January 2008, 17:20
Opel DTC P0400-5a
p0400-5a
p0400-5a zafira
Saab DTC P0400-5A
p0400-5a vectra
p0400 5a vectra c
p0400-5a vauxhall
opel p0400-5a
solstício verão 2017
Vauxhall DTC P0400-5A
Opel P0400(5A)
astra h p0400 z19dthp0400 code keeps coming on vectrap0400-5a vectra 1.9cdtip0400-5a opel vectra cvauxhall fault code p400_5ap0400 5a z19dtp04005a vauxhallcodigo opel p04005ap04005AVauxhall DTC P0400-05p0400 opel vectra cZ19 dth P0400-4Vauxhall DTC P0400-07p0400 5a vauxhall
