Results 1 to 10 of 11
Thread: Mounting TPMS receivers?
    Engine : 1.9 CDTi
    Default Mounting TPMS receivers?
    Does anyone have pictures or could tell me where the TPMS receivers are mounted?
    Aug 2010
    Stoke on Trent
    the NS front one is mounted on the body shell behind the wheel arch liner at the 2 oclock position. The NS rear is mounted on the inside of the actual wheel arch liner itself at the 2 oclock position.
    Engine : 1.9 CDTi
    Are there mounting points already there for them or marks in the plastic arch liner where to drill the mountings?
    Aug 2010
    Stoke on Trent
    I'm almost certain everything was there and I never drilled any holes when fitting mine.
    Aug 2010
    Stoke on Trent
    Ok... just been out to look at my rear arch liner and I have two screws that go thru the arch liner and into the receiver... I deffo never drilled any holes and the screws sit in recesses in the liner so you should be able to identify these two recesses visually without removing the liner... they are at the 2:30 position from the wheel center
    Full Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    In front the studs are ready just need the nuts, in rear i drilled the holes in plastic but they where marked an easy job.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Engine : 1.9 CDTi
    Thanks for the info.
    Know what I will be doing tomorrow after work
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    an old thread i know but, I had a look the other day on my signum and could not even find the studs let alone the wires/connector..
    Engine : 1.9 CDTi
    You need to pull the plastic liner away and look behind it.
    On the back there isnt anything.
    Jun 2009
    South Coast
    thats what i did, i removed the liner to get some bits of cat out of it and thought i would have a go at mounting my front tpms receiver while i was at it..
  1. Mounting TPMS control box?
    Last Post: 4th December 2012, 16:07
  2. Strut Top Mounting
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2012, 22:57
  3. PDA Mounting
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2007, 17:12
  4. Single DIN Mounting
    By bandrew in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2006, 01:53
