Thread: Bonnet opening
    Regular Member bigstorer's Avatar
    Swansea
    Default Bonnet opening
    Does anyone know how open a bonnet if there is something wrong with the pull?
    it seems to have gone wrong and now I can't open it.
    Engine : 1.9 CDTi
    Does it feel like there is tension on the lever?
    New Member Tmd's Avatar
    May 2011
    UK
    I suppose it's worth lying under the car and putting your hand up to try and reach the cable and yank it? Sorry not very scientific - best I can think of.
    Swansea
    theres no pull on it at all.
    took the lever off in the car and tried pulling the inner wire and nothing happens.
    I cant get at from underneath unless I remove the protector panels
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    big hammer
    WGAF#5
    It sounds like it's come adrift from the release under the bonnet ....
    once you get in it's only going to be a matter of reconnecting and adjusting but that's the easy bit
    the hard bit is gaining access with out causing damage
    Your either going to have to try and reach up and release from underneath or gain access from the lower grille .. I had a similar issue on my 2.8 a few weeks ago and the only access option I had was via the upper grille as there's not a lot of space in the engine bay but mines irmy and is different to the standard figment in your profile picture, which meant I had a slightly different tact on access
    Good luck
    Swansea
    managed to do it and heres how if someone else needs it:
    got underneath and undone the four plastic rivets holding the bumper guard on.
    remove the number plate
    push the top of lower grill until it pops
    back underneath and use a screwdriver to pop off the bottom clips until you can remove the lower grill.
    reach up through the gap until you can feel the bonnet pin.
    feel around until you find a round pin.
    use a screwdriver to force it out of place.
    The bonnet will pop.
    May 2011
    UK
    Good to hear you got it open, you need to tension the cable now. Someone put a simple how to on here to sort this out so it doesnt happen again.
  1. Opening the key fob?!
    By robk6112 in forum Troubleshooting
    Last Post: 13th June 2011, 21:32
  2. Boot Opening
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 20:46
  3. bonnet keeps opening!!
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 18th February 2008, 22:11
  4. Opening windows with key-fob
    By ghostrider in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 21:01
vauxhall vectra vxr bonnet will not open
bonnet pins vectra c
