Thread: Slight oil leak from sump plug.
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Default Slight oil leak from sump plug.
    Changed my oil on Friday, noticed this-morning there was an oil patch where I had parked my car last night.
    Took a look underneath - it was dripping from the sump plug - about a drop a minute.
    Got underneath the car & tightened up the sump plug abit more. - Didn't want to put too much pressure on it as I didn't want to strip the thread.
    Its slowed down the leak to about a drop every 15 minutes.
    Its not a massive leak - so im not going to loose sleep over it, but just wondering if anyone has had the same issue? The cars a 150 CDTi.
    Im thinking next oil change I will wrap the sump plug thread in abit of ptfe tape.
    Jan 2010
    glasgow
    there should be a sump plug washer/o ring like a copper ring on the bolt is there 1 on it ?
    Are the sump plugs not self-tapping? Isn't that why you are supposed to replace with a new plug after changing the oil?
    New sump plug might stop the leak?
    May 2011
    Liverpool
    Cheers guys, I used a new sump plug with the oil change and it did have an "o" ring.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by AlexGSi2000 View Post
    Might just need nipping up a little
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ive never had this problem & only changed the washer once in seven years!, but if you put grease on the thread & washer it usually does the trick.
    Essex
    Buy a new o ring when you change the oil next. Don't over tighten the sump bolt or you will strip the thread and have a massive repair bill.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    torque setting for the sump plug is 20nm if it helps
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Oil leak on my 2.0 T, not sump plug, any ideas??
    By Steve 100 in forum Engine & Drivetrain
    Last Post: 25th May 2012, 11:43
  3. 2.2 slight oil leak still.......
    By Lordish in forum Engine & Drivetrain
    Last Post: 3rd April 2012, 07:29
  4. slight oil leak
    By srikev in forum Engine & Drivetrain
    Last Post: 18th August 2011, 23:23
  5. slight oil leak
    By BRIANE in forum Engine & Drivetrain
    Last Post: 26th July 2008, 18:17
vauxhall astra oil leak from sump plug
