Results 1 to 10 of 15
Thread: cdti breath
    Regular Member toughmat's Avatar
    Home Rhondda , Work in Cwmbran
    Default cdti breath
    Before I get a remap next month im looking to help the CDTI to breath better.
    Are there any other mods that you can do other than the Air Box Mod???
    Sep 2010
    west sussex
    what's an air box mod?
    do a a search there is a how to around
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Quote Originally Posted by bigcarp1953 View Post
    http://www.vectra-c.com/forum/showthread.php?t=15122
    This will answer your questions
    can we get back on to the subject
    Regular Member badback's Avatar
    Runcorn
    I've put a pipercross air filter in mine at the same time I had it remapped. I've had the car over 4 years now, and it's running better than ever.
    West
    don't bother with open cone filter induction, if you want to improve the breathing either buy a decent high flow panel filter or replace the lot for an enclosed high flow induction kit... simota, bmc etc...
    Can i drill a few extra holes in the air box
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    also try a vxr intake
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Watching this thread, and you want the engine to breath better?
    Personally I would cease looking at the airbox, unless you plan to fit a K&N panel filter or similar.
    If you are going for a remap, are you planning on getting the EGR valve disabled? It will help engine response at lower rpms. Downside is that it increase exhaust gas temperature, with the potential of taking out the turbo - yet there haven't been any turbo failures in the CDTI's yet afaik.
    I have blanked the valve off and removed the throttle plate alongside the airbox mod, do I notice a difference? I do a bit but I have to say not much.
    Airbox mods tbh are in the head I think, yes some have drilled holes in them and noticed a difference but I'm not sure the benefits are there to be had by all.
    As for making the engine breath better there isn't much you can do and tbh more air doesn't really affect diesels like petrols. All it will do is relieve some horse power but even that has a limit.
  1. make's it breath easier.....
    By ditchp in forum Diesel Engine related
    Last Post: 22nd September 2007, 20:39
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
