Results 1 to 10 of 20
Thread: Enable seat belt warning on Vectra C 06
    New Member Pigsear's Avatar
    Jun 2011
    Berkshire
    Default Enable seat belt warning on Vectra C 06
    Hi guys
    Have just bought a Vectra C estate Exclusiv after my old Omega got rear ended
    I like the Vectra, had Vauxhauls for donkeys years. Having read through the seat belt threads on here it sounds sas though my car should have the warning and chime. I know I will want it gone after a day, but I would loike to know it works, if you know what I mean.
    There was no sign of the warning light, not even in test mode at switch on.
    I had a m8 check it with tech2 and he enabled it in the seatbelt section. Now the light comes on at ignition, but then goes out. I see the wiring under the seat but all looks in tact. I hve not put a mirror under, just peered from footwell. I will try with a torch in case.
    I read that if you remove the fuse/relay then the indicator clic noise gets disabled. Well that works OK. I also read that if you unplug the pasengers underseat wiring that it can disable the pasengers air bag ^^
    If the underseat wiring is not the issue, any ideas how it has been disabled?
    Thanks for your help.
    Alan
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    what fuse/relay for the indicator 'clic' u refering to??
    Jun 2011
    Berkshire
    Hi nikroc
    I am not sure where, I just rem someome saying that if you remove the fuswe for the seatbely warning, that it stops indicator and wiper off click noise.
    I have had a gander under the seats and the two plugs seem to be connected.
    Alan
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I thought they removed the seatbelt warning in later models. I know my 03 plate had it, but my 54 plate doesn't.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Ian-Highlander View Post
    Yip bit I don't think they removed the whole lot m8. If yours is half canbus you may get away with just getting it enabled.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Lol, don't want it, it was sodding annoying
    Jun 2011
    Berkshire
    Thanks, what do you mena by ' half canbus'?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Pigsear View Post
    If it's half canbus it will have the 6 buttons on the steering wheel - 3 either side. As yours is an '06 it will have scroll wheels on the steering wheel meaning it's full canbus.
    Full canbus is on any Vectra registered after mid October '04.
    Jun 2011
    Berkshire
    OK, thanks.
    How would you go about fuinding out if it should be on or has been turned off?
    Alan
    Glasgow
    Early vectras had it my 53' GSi did and late ones my 09' VXR does'nt, strange as its only a software change that would have deleted it so it cant be put down to a money saving thing.
  1. seat belt warning buzzer
    By mabski in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 10:40
  2. Seat belt warning
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2009, 22:30
  3. Help seat belt warning light
    By steve-wolves in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 14:37
  4. Temp Gauge & Seat Belt Warning
    By Oscar Ding Ding in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2007, 20:12
  5. seat belt warning not on
    By IanW in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2007, 07:35
vectra c seat belt warning
https:www.vectra-c.comforumshowthread.php141994-Enable-seat-belt-warning-on-Vectra-C-06page2
vectra c seat belt activate
vectra c seat belt warning not working
how to activate my seatbelt alarm vauxhall vectrahow to activate and deactivate seat belt alarm in my vectraopel signum deactivate seatbelt beepmy seatbelt buzzer wont work on my astraVectra-c seatbelt warning not working Got no seatbelt warning light on 2006 vectra 2.2 direct vectra c seatbelt sound enablevectra c seatbelt sensorseat belt light staying on on a vauxhall vectra clubastra 2007 seat belt sensor not going offcorsa c seat belt warninghow to activate seat belt reminder on insigniaturn off seat belt chime signum vauxhall zafira seat belt warning lightvectra c seat belt warning turn offvectra c seat belt enablevauxhall vectra seat belt warning lightHow do I activate the seat belt warning on a 2006 opel corsa c sportopel z20net temperature gauge between 80 and 85 www.vectra-c.comcorsa c seatbelt warning onhow yo stop seatbelt alarm vectra c
