Thread: my signum has developed a leak
    Regular Member elite lee's Avatar
    torquay
    Default my signum has developed a leak
    as the title says.
    it's internal. going to have a look later, but just wondered if anybody else has had this problem.
    whenever it rains I'm getting water coming in from the passenger side footwell, seems to be at the back of the glove box just to the right as you look at it.
    it's a fair bit of water to, not just a bit.
    any help would be great
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    loads of posts on this mate its the scuttle drain
    bet your heater blower has packed up as well
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    you need to clean out the scuttle tray underneath the front window ...remove the pollen filter and check there for the fault ..there is a drainage hole which often gets crud and stuff in it ..
    Aug 2010
    Luton
    http://www.vectra-c.com/forum/showth...=scuttle+drain
    check here or search "wet footwell"
    torquay
    Quote Originally Posted by markj23 View Post
    heater is fine mate, did think it could be the matrix but i'm not loosing water
    Aug 2010
    Luton
    Quote Originally Posted by elite lee View Post
    you have been lucky then so far clean the drain out asap
    torquay
    i'm on it, thanks for (as usual) the great help. will keep you updated
    torquay
    a very simple job that has caused me no end of problems is sorted. i have been worried for nearly a week about this. i have just spent the sum total of 5 mins 9 seconds on this and its done, in that time i even sorted my insignia washer jets.
    problem sorted with a finger down a drain hole.
    thanks guys
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    thanks guys
    lol yep just keep checking by sticking your finger down said hole and it avoids all the damp carpets.
  1. water leak Signum
    By ian coulton in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2011, 06:52
  2. Who has developed the Insignia diesel ?
    By baard in forum Insignia Chat (READ ONLY)
    Last Post: 5th March 2009, 00:03
  3. Dti Developed Horrible Rattle
    By craigbarlow18 in forum General Chat
    Last Post: 9th November 2008, 00:21
  4. Developed a squeak!
    By matth42 in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2008, 14:38
  5. My Auto has developed a serious problem!
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 16:32
