Results 1 to 10 of 16
Thread: losing boost pressure
    Worksop
    Default losing boost pressure
    boosts up to 0.9 bar in 4th then drops to 0.4then up again upto redline this seem right for a remapped 2.0t
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    No, the boost should hold steady and drop off very very slightly at the top end of the revs, mine boosts to 1.1 bar and drops to about 1 bar at the high end of the rev range.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    prob a crap remap mate had a evo in the workshop the other day with the same prob turned out it was a dodgy map
    Worksop
    Quote Originally Posted by Ian-Highlander View Post
    what can be causing the drop ian
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Weird one as you say it's holding fine "all the way to the redline" once it picks back up past the drop which would suggest your vacuum and boost pipes and sensors should be ok.
    It may be over-boosting and the ecu is compensating but I wouldnt expect it to be steady all the way the rest of the time in that case.
    Unless anyone else can come up with another suggestion, it does sound like it's map related to me I'm afraid.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    have you looked at all the boost pipes mate just in case
    Worksop
    redone most of em with silicone one got one to do under turbo and a couple of vac pipes left could this be a actuator prob weak spring
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Anything's possible, but it's your statement that it boosts back up fine and stays there til the redline that confuses me.
    The fact it's dropping boost at one point in the rev range suggests too much boost/not enough fuel at that point which would be map related.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    possibly mate who did the map have u ever had it rollin roaded
    Worksop
    darrell did the mapping on it
  1. losing boost sri 2.0t really annoying
    By tomo41 in forum Engine & Drivetrain
    Last Post: 22nd August 2013, 23:41
  2. 2.0t boost trouble keep losing the turbo
    Last Post: 28th July 2012, 13:25
  3. 1.9 150 CDTI losing power/boost
    By jay w in forum Engine & Drivetrain
    Last Post: 26th February 2012, 22:57
  4. Losing tyre pressure?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 20:28
  5. boost pressure
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 6th March 2010, 14:47
