Results 1 to 10 of 11
Thread: Air Con condenser broke
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default Air Con condenser broke
    Hi All,
    Took the vectra SRI 1.9CDTI SRI 150 Into vauxhall today to get the air con regassed and came back that the Air con condenser was damaged and needs replacing. So is holding no air con.
    I understand that this sits in front of the radiator, so looks like would be best to remove front bumper to replace?
    Anyone got a guide how to replace the condenser?
    Or know if it is a big job?
    cheers
    May 2008
    Middlesbrough
    first ? m8 is your car out of warranty?
    dealer quote for this job are 450 inc labour and regas
    Sep 2010
    Lincs
    Yeah its a 2006 so not covered.
    I have found a how2 guide: http://www.vectra-c.com/forum/showth...84#post1277584
    But it says to make sure i remove the refriddgerant before replacing condenser. any ideas where this is and if its hard to remove?
    Also does my car have a dryer attached to the condenser? ta
    Full Member
    Bristol
    I just had mine done for £160
    Jul 2009
    Wiltshire
    Quote Originally Posted by 150_SRI View Post
    If the condenser is holed, the refrigerant will be gone anyway.. I did the how2 on a 2008 1.9 SRi CDTI150XP, if that helps. The dryer was not attached to the condenser on mine.
    Edinburgh
    I have an 06 1.9 CDTI 150 and the dryer isn't attached to the condensor on mine either.
    Sep 2010
    Lincs
    Hi Guys, still need a condenser for my vectra. Spotted one on Ebay brand new for £78: http://www.ebay.co.uk/itm/VAUXHALL-V...item415c093f67
    Then spotted another one for £125 that says its a genuine VALEO: http://www.ebay.co.uk/itm/VECTRA-SIG...item53e87d7c67.
    The £78 doesnt seem to say what make it is. Do you think i should get the VALEO one or the chaeper one?
    Sep 2010
    Lincs
    I have been to vauxhall to order the seals and they have located them, but said i need to measure the seals to ensure we get the right ones, but i cant as will mean taking the bumper off then putting it back on. Anyone know what size seals are needed for the condenser?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    I'm just about to change mine , Ive got a new one from Fleabay and was going to get it regased
    Do I need new O rings then, ??
    Jul 2009
    Wiltshire
    Have a look at the first photo in my How2.. I made sure I took the first photo with the part numbers showing..
  1. AC condenser
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2012, 11:59
  2. A/C condenser
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 19:59
  3. A/C condenser
    By xaviroller in forum Bodywork & Interior
    Last Post: 8th July 2009, 11:56
  4. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
replacing air con condenser vectra c
How to replace 2008 vectra diesel condenser
vectra c forum air con
vectra c condenser replacement
vectra c condenser o rings and seals
vectra c replace condenser reuse seals
vectra c air con o ring sizes
vauxhall vectra c condenser o rings
vauxhall vectra c aircon o ring lubricant
how to change the condensor on a vauxhall zafira 1.9cdti
vauxhall aircon seals
air con compressor change vectra c
signum conditioner radiator change
vectra c air con condenser replacement
