Results 1 to 3 of 3
Thread: Bad Battery Regen causes Lumpy CDTI idle ?????????
    Regular Member thefibreguy's Avatar
    bedford
    Default Bad Battery Regen causes Lumpy CDTI idle ?????????
    Guys,
    Seems a lot of us 1.9CDTI owners suffer from lumpy tickover on start-up, which seems to get better as car warms up.
    I had this problem, & my local mechanic chappie told me that due to the relatively poor regneration of my battery after initial start-up, the injectors do not have the power to pump the right amount of fuel, which I suppose would cause the poor idle!!
    Sounds plausible to me, so will invest in a new uprated battery, & see if it cures the issue.
    Any comments/thoughts welcome
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    cant see it as iv got a 7.5 ton lorry battery on mine and its still lumpy.............could work tho id love mine to stop the lumpy tick over
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Its a trait of the cdti/alternator. It doenst start charging the battery properly until a little blip and then it charges at 13.8-14.4volts
  1. sri cdti 150 lumpy idle/ low mpg?
    By stevesri in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 20:39
  2. CDTI lumpy idle & smoke?
    By bigdave1701 in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:48
  3. 1.9 CDTI Lumpy Running at Idle
    By Dazfoz in forum Engine & Drivetrain
    Last Post: 13th April 2009, 18:23
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. Signum 1.9 CDTI 150 ( runs lumpy when cold only on idle ?? )
    By Longtallhowie in forum Engine & Drivetrain
    Last Post: 12th April 2007, 20:57
1.9 cdti can alternators cause bad idle
