Results 1 to 10 of 13
Thread: Is there supposed to be a coil on display when starting?
    Jul 2011
    kent
    Default Is there supposed to be a coil on display when starting?
    Is there supposed to be a pic of a coil come up on the display when starting the engine?
    And also is the spanner supposed to come up for a few seconds when starting?
    Assuming you're driving a deisel, it's the glow plug light mate. The spanner light is normally on during start, and once the engine management knows the engine's running and everything is fine it goes out...
    On a 2003?
    What engine?
    I agree, coil should briefly appear
    Spanner should never appear, only appearing if something is wrong
    Jul 2011
    kent
    its a 2003, 2.2 dti.
    No coil comes up, thats why im asking wether it should.
    The car and spanner comes up when you first turn the ignition on and goes out again like the other lights etc. is that right?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    no coil sign until it gets down to about 5º c and i dont get the spanner sign when i fire mine up..
    im sure that means its got old codes stored that need clearing, and i think that if the coil lights up, it means theres a fault with the glow plug system
    2.2 dti.... 54 plate.
    al.
    Jul 2011
    kent
    ******. Ill have to get that checked out then.
    Each model is probably different, but if there's no lights on when the engine is running then there's no issues. If the coil comes on for a few seconds then goes out, and it's cold outside, then it's the glow plug light. If it doesn't come on then it's above 5 degrees. If you're not having any problems starting, then you've nothing to worry about mate...
    Jul 2011
    kent
    the coil light is not an issue. It hasnt come on at all but im assuming thats because its not cold enough. Just thought it might come on all the time because my 58plate movano does.
    Its the spanner/car light that comes on when ignition is turned on that i was worried about..
    As far as I am aware, the coil light should always appear briefly (see handbook)
    On first start for about 2 to 5 seconds, depending on temperature
    On second, or more, starts it may not appear or for less than 2 seconds
    On mine it appears for about 2 seconds
    Also on subsequent starts it always appears briefly
    However, if I switch off and back on again straight away it does not appear
    On a previous car it would appear for about the same amount of time
    However, near the end of the life of the glow plugs the light stayed on for much longer
    The one nearest the glow plug relay was white in colour and had failed, so all four were replaced
    Quote Originally Posted by AdDaMan View Post
    Unless it's on while the engine's running I wouldn't worry mate. Unless you can get any codes read for free it'll be a waste of money finding out if there are any...
  1. was supposed to buy an engine but...
    By IDVAC in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 18:21
  2. is oil supposed to be here?
    By G19RKE in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2012, 23:41
  3. It's supposed to be summer-look outside!
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 25th July 2009, 14:10
  4. Ignition coil and problem starting?
    By emptybee in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:36
  5. Not Sure if it's supposed to be doing this???
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 28th August 2008, 20:42
vectra c dti glow plug light doesnt allways light up
