Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Possible to fit auto lights/wipers
    Engine : 1.9 CDTi
    Default Possible to fit auto lights/wipers
    Is it possible to fit auto lights/wipers to my Signum?
    Just picked up the sensor and an auto dimming mirror from the Scrapyard.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Wipers yes but I believe the headlights are a facelift only retrofit
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    just done wipers and lights on my 06 Sri
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Not quite John I retrofitted it to my car which is a pre-facelift full canbus same as Lee's. You need to check how many wires you have on the back of the plug going into the light switch if you have 10 then you need to buy a new light switch and have it enabled. You have to be careful with the wipers as they made more than 1 module so it depends on your existing wiring loom in the overhead panel and for the mirror you need a loom running from the mirror to the REC which is about £35 from Vx.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by paulhb View Post
    Must be a full canbus thing, I know there are some that can't be retrofitted with it all
    Engine : 1.9 CDTi
    Is my Signum likely to have the loom in the headlining?
    How easy to check (And where)?
    will pull the headlight out in a bit and report back how many wires I have going to it.
    Engine : 1.9 CDTi
    Just been out and I do have 10 wires.
    Also where does the module go?
    Is it worth me going back to the scrapyard and getting the roof loom and anything else I need from it (What and where are the other bits I need)?
    Aug 2010
    Stoke on Trent
    lee... I have an auto lights switch if you don't have one... I was going to do auto lights but decided against it...
    Engine : 1.9 CDTi
    I don't so that will be ideal.
    Pm me what you want etc.
    If I retro fit auto lights and wipers will my windows roll up if it rains like when fitted as standard?
    Also how does this sensor fit to the screen as the car I took it out of had some sort of bracket bonded to the screen that wouldn't come off.
    Aug 2010
    Stoke on Trent
    Will do Lee once you are certain you want it because to fit that sensor I believe you will need a new windscreen.... this was one of the things that put me off doing this mod.
  1. The start of my mod to auto wipers and lights
    By jon1.9cdti in forum Styling
    Last Post: 8th May 2012, 12:29
  2. Auto lights/wipers and 'frost'
    Last Post: 20th January 2012, 11:55
  3. auto lights and wipers not working
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2011, 22:07
  4. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  5. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
