Results 1 to 10 of 20
Thread: 2.2dti cutting out!!
    Northampton
    Default 2.2dti cutting out!!
    Hi,
    Got a worrying problem with my 53 plate 2.2dti Signum. About a month ago while on the M25 the car/spanner light came on on the dash and all power was lost, managed to coast to the hardshoulder turned the ignition off then started the car again drove a little way and the same happened again and then once more. Stopped at the services for a while then started the car again all seemed well no lumpyness or anything so carried on my way. Since then the cars been fine.............. until tonight, it did the same thing on a busy roundabout, got it started again drove a short distance then it did it again, got it started again and it seemed fine took it all the way through the rev range no problem. I've done a search on the board and found some references to crs going into limp mode but mine looses all power.
    Anyone else had this happen?? I guess I'd beter get in touch with a dealer.
    Could be the (becoming somewhat common) split boost hose problem.
    http://forum.vectra-c.com/showthread.php?t=10492
    That's a start for you. Have a good read through that and see if you think that's what maybe the problem on yours.
    HTH
    If it's totally dieing then also get them to have a look at the fuel pump.. they're electronic so may be the cause of the breakdowns..
    Northampton
    Well it feels like its totally dieing but it actually drops down to a very lumpy tickover (feels like 100 rpm) and won't pick up until it's turned off and back on again but it is totally undrivable when this happens.
    Nr Cardiff
    Fuel pump mate. Been there done that!
    Northampton
    Would that be covered under the warranty? (3 yrs is up at the end of Oct)
    Yep - it will be (as long as you're under 60K). Get it in quick!
    Northampton
    Well the car has now been into the dealers and they diagnosed a faulty throttle body which was replaced within an hour. Initial reaction is all's good but time will tell as the fault happens without rhyme or reason.
    Fingers crossed.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Quote Originally Posted by SteveA
    Hi,
    I had a similar problem on my veccy and found it to be the boost hose. mine split (god knows how!?). all i did was get some silicone piping from local TMC for couple of quid and was sorted.
    Full Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Quote Originally Posted by SteveA View Post
    Fingers crossed.
    Hi,
    same problem on my 2004 Vectra 2.2 DTI and same solution!
    It was changed yesterday, now the car seems to be ok!
  1. cutting out again :@
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 07:50
  2. Cutting out
    By Chuddy in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:37
  3. my car kept cutting out??
    By Curly7 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 21:23
  4. Help car cutting out!!
    By chrisc1981 in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:28
  5. Key Cutting
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 22:32
