Thread: Thermostat manual opening...
    Default Thermostat manual opening...
    As part of my upcoming work on the car I'm planning on changing the coolant. To drain and flush the engine properly, it is recognised that you have to remove the thermostat because when the engine is cold it blocks off the radiator. Could you fool the valve into opening purely by applying a 12v supply to it? I've done the same with the EGR valve to test it, but is the thermostat just as simple?
    Someone with TIS should be able to find out I hope...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not sure what you mean mate, thermostats are operated purely by the temp of the water and a spring. You can test it by dropping it into a pan of cold water and then heating it up. As the heat goes up the stat will open
    They are easily removed for testing/flushing purposes though
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above mate its the wax in the thermo stat that controls opening.
    Ok, now that I've made myself look like a moron, I shall look into removing it instead. Cheers chaps...
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Maybe easier to remove heater matrix pipes and flush system out that way
  1. Door not opening
    By sproket in forum Bodywork & Interior
    Last Post: 29th June 2012, 08:36
  2. Name of tool for opening hose clips on Vectra C thermostat connections?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 06:32
  3. Thermostat manual opening...
    By Penfold101 in forum Engine & Drivetrain
    Last Post: 9th July 2011, 11:42
  4. Opening the key fob?!
    By robk6112 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th June 2011, 21:32
  5. Vectra SRI 150 Manual and CD70 Manual?
    By rscosworth in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2005, 22:30
