Thread: egr valve
    Jul 2011
    liverpool
    Question egr valve
    A bit of help cleaning egr valve for the first time do i need new gasket kit and do i buy some decoke spray then cover the egr init then wipe off and refit please help im a newbie
    Aug 2010
    Derbyshire
    Quote Originally Posted by hbomb View Post
    This is what you want
    http://cgi.ebay.co.uk/GENUINE-VAUXHA...item2eb572b833
    That's if your talking 1.9 150 engine, not sure about the 120 engine.
    There is a link to how you remove the EGR with good pics, but was never made into an "how too", well at least I can't find it.
    Dead easy though, remove 4 long bolts that fasten it to the inlet manifold, and 2 bolts that fasten to the exhaust link pipe underneath.
    Don't pull it away yet as there is a electrical connector block to remove. I found it easier to disconnect this last as it's a bit fiddly to get at below. Slide yellow clip out, not all the way out though and ease apart the connector.
    You will see what wants cleaning and whether the piston and spring are seized. You can get the section apart (would have helped if I could have found the thread on this, somebody?)
    Good idea to remove and clean the throttle body as well. I used petrol to clean both parts, soaked the EGR in it overnight. Or use carb cleaner.
    BTW watch out when removing the parts as those gaskets have a mind of there own and disappear down into the depths of the engine compartment, never to be seen again. Not so bad if you're fitting fresh one's though.
    Oh and once done use this http://cgi.ebay.co.uk/wynns-egr3-air...item2302ed7024 to clean your inlet manifold.
    I just sprayed mine into directly into the manifold via the throttle body in short bursts, after cleaning it and the EGR.
    Mick
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    http://www.vectra-c.com/forum/showthread.php?t=45867
    Here is what you are looking for ! hope this helps.
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    I have a 3.0 ltr V6 CDTi engine, will mine need cleaning?
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
