Results 1 to 3 of 3
Thread: Help!! LED sidelights flashing!!!
    Apr 2011
    Cornwall
    Default Help!! LED sidelights flashing!!!
    Hi everyone,
    Ive just installed some DRL's as you can see on my how2 thread so changed by sidelight bulbs for LED ones. I bought the canbus error free ones and with a bit of fiddling they dont set off the canbus error but flicker or flash when the ignition is on and after its turned off fo about 20-30 seconds.
    I bought a pair of resistors which go inline and plug into the 501 bulb socket and give you a seperate one to plug your LED lighrs into, which was supposed to stop the flashing - however now fitted they still flash!!!
    I wouldnt mind quite so much if I hadn't had someone pull over for me the other day assuming I was in an undercover cop car!!!!
    Has anyone else fitted LED 's without the flashing or is this something I'm gonna have to put up with? If so will it not fail an mot?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    will always strobe.
    thats just vectras and led's im affraid.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    What he said!
    Also search is your friend
  1. New LED Sidelights
    By jamesmcuk in forum Styling
    Last Post: 20th October 2012, 15:34
  2. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  3. LED Sidelights???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 00:03
  4. what sidelights???
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 02:38
  5. Sidelights
    By Danwells72 in forum Styling
    Last Post: 18th August 2008, 07:36
saab 9-3 led flashing
saab 9-3 led sidelights
