Results 1 to 10 of 14
Thread: vectra c 2,2 petrol sri
    Sep 2010
    leeds
    Question vectra c 2,2 petrol sri
    just changed spark plugs and oil filter yesterday, in the rain! plus rear pads. All gm parts. One hour on the classic missing problem and loss of power when booting it. Engine light only comes on when I boot it. Goes off when engine is switched off. Dealers changed the fuel pump last year £780, no contribution. Has the pump gone again?
    Full Member spennny's Avatar
    Blantyre
    £780
    have u had the \FPR changed
    Regular Member srikev's Avatar
    Jun 2011
    Chester
    Vehicle : Vectra c
    Trim : Sri
    Year : 03
    Mileage : 105,000
    wow. did they see you coming pal =-O
    think spennny may have a point .
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    I had the Fuel Pressure Regulator changed under a recall last month and mine has been miss firing ever since.
    Dealer wants me to pay for any investigation even though it was not there before they got their hands on it
    Mar 2011
    Northern Ireland
    quick follow up...
    just out of the dealers, they are looking to take the back in and swap out the FPR for a new one. This will be ok if it fixes the misfire, but if it doesnt then I need to foot the bill and also whatever other investigation is required to actually fix the fault
    The ECU light does not come on and I have no Fault codes logged when I connect a U480 coed reader...
    Any ideas?
    Blantyre
    Mine did the same mate , no codes stored, Vx found out it was the HPFP that was throwing the fault up, and not the regulator Got it changed in 30 mins at a cost of £365 i think ?
    Must have taken their time with the 3 bolts that loosens it !!
    Mar 2011
    Northern Ireland
    Not Good Car just out of warranty too.
    I assume whatever they disturbed when changing the FPR has caused this, but how would I prove that!!
    I am maybe starting to regret buying the 2.2 direct
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    got the same problem mate they are saying mine is heat related though
    Mar 2011
    Northern Ireland
    I have seen the heat related stuff in a few other threads, but assumed it was to do with something else...
    My concern is if the new FPR are heat sensitive then another new one will not cure the problem and I will be left with a big bill and a broken car
    Aug 2010
    Luton
    I have taken the heat shroud (plastic cover ) off my engine to see if it makes a difference
    not been anywhere yet to see if it works
  1. 2.2 Petrol Vectra
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 12:03
  2. vectra 2.2 sri petrol
    By lordreeson in forum Engine & Drivetrain
    Last Post: 29th October 2010, 20:06
  3. Vectra sri 2.2 petrol
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2009, 20:48
  4. vectra 2.2 petrol
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 00:37
  5. Vectra sri 1.8 petrol - fsh 39k
    By arkhan78 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th January 2009, 00:04
