Results 1 to 10 of 29
Thread: hid fitting
    Oct 2010
    TELFORD
    Default hid fitting
    Hi all, just been flicking through the how 2s on fitting hids is it absolutely necessary to remove the front bumper for fitment? Also what are the best to go for? Thanks
    Full Member
    Bristol
    Yes you will have to remove the front bumper. Make shure you have the correct clips to fit bulbs. the one standard on the car will be no good. Also if you have a full computer you will have to install cancellers or the computer will keep telling you that a buls is out.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    You Can Fit H.I.D`s Without Removing Front Bumper...Not Much Room Likes..If You Got Hands Like Shovels...Forget It lol
    Aug 2010
    Stoke on Trent
    remove the screws in the wheel arch and plastic rivets in top front of the bumper then ease the bumper out and away from the wheel arches then you will have enough play to tip the bumper forward enough to get at the bottom bolt/s
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    mine were fitted with bumper on with no hassle. thanks to "enery" got a preface tho.
    scottish region
    Waste of time taking bumper off mate can be done no probz
    Another vote for taking the bumper off. Far better than losing the skin off the back of your hands with the sharp corners of the airbox and its mounting brackets.
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    If you have a pre-face, No, you DO NOT need to remove the bumper, its easy to fit them, its far easier removing the airbox than the front bumper lol, do your airbox mod at the same time
    Sep 2010
    surely depends what engine you have?!?!?!?!
    Jan 2008
    Newcastle
    Why would it depend on engine ?
    Are you refering to the hids or the airbox mod ?
  1. hid fitting
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:25
  2. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  3. When im fitting
    By PAULMAC77 in forum Styling
    Last Post: 3rd April 2009, 15:30
  4. fitting a PS2
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 09:30
