Thread: Facelift Vec Estate Interior Rear Tailgate Cover
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Default Facelift Vec Estate Interior Rear Tailgate Cover
    Has anyone removed this card. I pulled out the cover plug for the manual release and the 2 plugs from the bottom(facing you when tailgate is open) but the card is firmly attached to the car. I didn't want to pull it too hard because knowing my luck the damn thing will rip in 2.
    Is there a sequence for taking it off. All I want to do is to wire my non working fog light up.
    Any help is appreciated, thanks.
    When i saw GG take the cover off his bootlid, he removed 1 torx screw from the inside of the rear pulldown handle..
    then all you have left to do is pull it 'firmly' down as the rest of the clips are popstuds..
    Thanks for that, I will have a look for the torx in the light of a new day and give that a go
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Gsi3.2
    Sounds exactly like the Signum. Just be careful when pulling the trim off as you can break the odd spring clip (easily replaceable after a trip to the dealer! )
    Hertfordshire
    Yep, what he just said, plus two plastic rivits right by the lock, you have to pull the centres out first.
  1. Rear Tailgate not Opening on vectra estate
    By si_sri in forum Bodywork & Interior
    Last Post: 28th November 2009, 21:06
  2. Vectra Estate Tailgate Interior Pull Handle
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 14:59
  3. Rear Interior Light in an 06 + Facelift Estate
    By logi6260 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 20:56
  4. Estate tailgate interior trim removal
    By parapaul in forum Bodywork & Interior
    Last Post: 27th December 2006, 14:24
