Results 1 to 10 of 20
Thread: EGR Valve question
    Regular Member CH-VECTRA-ELITE's Avatar
    May 2010
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Default EGR Valve question
    Whilst finding that my boost pipe had split and I was doing a temp fix, I thought i'd see how hard/easy it was to take the EGR valve off and give it a clean.
    As I expected it was full of crud but the solenoid area was nice and clean and was moving freely. So my question is do I drill a 3mm hole on top of the valve so I can spray WD40 in it to keep it moving freely or just leave it??
    I run out of carb cleaner so need to take it back off again to finish cleaning, but will order the fiat gasket plates and put them on after the clean. Even with the temp fix on the boost pipe and a semi clean EGR valve the car drives much better, pulls away better than it ever did in the year that i've had it, but also now my EML is on, i'm guessing it's because I took the EGR off but i never started the car while it was off shouldn't it go out or will i now have to get a tech 2 connected to clear all the faults. Maybe the EGR valve is faulty???
    May 2010
    Frimley
    Mileage : 140000
    Jul 2011
    liverpool
    Default smoke
    did u have smoke coming out the back is that why u took the egr off or hoses split if so did it solve the problem i have the smoke when starting and pulling away from the lights any help will do thanks
    May 2010
    Frimley
    Mileage : 140000
    never had any smoke come out of the car. I've always had lag on acceleration and it got worse last week, so checked the boost hose to find it has a big split, so took the EGR valve off as well to see how dirty it was. Car has improved a lot but now i have the exhaust gases warning light.
    Jun 2007
    chesterfield
    you might not get much smoke on the estate as the DPF will filter that out, but beware of it getting clogged up
    May 2010
    Frimley
    Mileage : 140000
    maybe but my car has never done a regen in the time i've had it so not sure if the DPF has been mapped out
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by CH-VECTRA-ELITE View Post
    Hi, Just replaced my EGR and cleaned the boost sensor as well as replacing the vacuum pipes - runs a lot better but still a flat spot / stutter when accerating in first and second gear - I now want to try the Fiat gaskets - do you have any further info and where do I get them
    also do I need 2 or will one do the job, Thanks
    May 2010
    Frimley
    Mileage : 140000
    http://www.vectra-c.com/forum/showth...t=48513&page=5
    Have a look at this thread, picture of gasket is half way down page, part numbers on page 6
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Hi Thanks for the reply - sorry should have said mine is the 120 - if I can find a picture I will make one (or two) out of copper plate
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    A valve which fails to open due to solenoid failure (open circuit) will put the spanner light on. If the soleniod physically doesn't work - ie move with an electrical signal or the valve is blanked it will put on the emissions light.
  1. 2.2 Direct EGR valve question
    By andrewleighton in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:31
  2. EGR Valve question about cleaning
    By steeley7 in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 17:09
  3. Swirl valve question
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 17:23
  4. Another EGR valve question
    By aerodynamic18 in forum Diesel Engine related
    Last Post: 11th February 2011, 18:39
  5. EGR Valve Cleaning Question
    By corderz in forum Diesel Engine related
    Last Post: 31st January 2011, 21:57
vectra c 120 clutch bleeding
