Thread: What Have I Done? (also Clutch Bleeding Nipple location)
    N
    Default What Have I Done? (also Clutch Bleeding Nipple location)
    Hi,
    In my haste, I noticed a bicycle style release valve on a pipe and mistook it for something else. I held it for a while and released a lot of air, and then suddenly yellow fluid came out? Car seems fine though but wondering if someone could tell me what it is, and what I've done by releasing all the air? Its this one here:
    Also could someone tell me where the clutch bleed nipple on my 03 Vectra 1.8 is?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Think Thats Air-Con Pipe..Sure Somebody Will Put You Right Though
    N
    She'll need re-gassing then.....or not! Never used Air-Con in the 2 years I've owned this car
    EDIT: Whoops So does that mean I released CFC's and not air? Don't I feel like a huge idiot
    WGAF#5
    yep ac pressure valve ..... you will have released refrigerant into the air and killed lots of small fairys and pixies in the process ....
    did you not get any compressor oil leak out ??? (yep that would have been the yellow stuff)
    and more importantly what were you trying to vent
    Last edited by Deztroyer; 7th July 2011 at 16:35. Reason: noted that stated yellow fluid leaked = evaporator ooil
    Sodding Typical on Sea
    Yip it's the A/C gas low pressure side. Never wise to "not" use the system as it will run up huge bills from lack of use and is a real asset in a car even when it is cold!
    lack of use will cause the compressor to fail the condenser to rot etc, 10 mins running every week is all it take to maintain it in tip top condition.
    Engine : 1.9 CDTi
    As said that was the aircon gas.
    As for the bleed nipple its on the pipe coming out of the gearbox under the battery tray
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Engine : 1.9 CDTi
    Or increasing your chance to get skin cancer etc: www.freeautomechanic.com/airconditioning4.html
    Oct 2010
    London
    Why on earth did you vent it out not knowing what it was? :|
    West
    It's illegal to vent that stuff to atmos btw
  1. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  2. clutch bleeding
    By bigbossgk in forum Engine & Drivetrain
    Last Post: 11th May 2012, 18:15
  3. Bleeding the clutch on 3.2GSI
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 00:29
  4. Bleeding the clutch
    By lee gsi in forum Engine & Drivetrain
    Last Post: 21st May 2011, 15:46
  5. Clutch Fluid Nipple
    By dekd in forum Engine & Drivetrain
    Last Post: 27th February 2010, 13:25
vectra c 120 clutch bleeding
