Thread: 1.8 VVTI and Airbox mod
    Regular Member GoldenWonder's Avatar
    Durham
    Default 1.8 VVTI and Airbox mod
    I've only had my 1.8 for a few weeks and I did the airbox mod straight away - it made a subtle difference to the throttle response on my older cdti so I thought I may as well.
    Thing is, on the 1.8 I find it very hesitant on the throttle, and then its up to 2k rpm at the slightest touch which makes it a nightmare in traffic. I've also noticed a sort of 'drone'/engine boom at 2k rpm regardless of road speed so i'm wondering if the air box mod does more harm than good on the petrol engines?
    Dunstable
    I did the airbox mod on mine and I wouldn't say it's done anything to harm the engine. Along with a k&n air filter it seems to be a little more responsive, though it's probably all in my head
    Durham
    I'm toying with idea of a k&n air filter - would it smooth out the 'jerk' I seem to get on and off the throttle (usually at 40mph plus)
    Sep 2009
    Audley STAFFS
    20,000 mile with the air box mod done, and have no problems. did you fit a NEW air filter when you did it?
    Durham
    No, the air filter was almost new when I did this. Barely any muck showing at all. 3k since the last service so it looks like it was changed then.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by GoldenWonder View Post
    OK mate.
    Sep 2009
    Audley STAFFS
    your drone/engine boom, are realy sure its coming from the engine,, when I first got this vec at lowish revs I could hear what I thought was a drone engine boom, had to change the tyres (ling longs) to Falken and the noise was gone
    Durham
    The drone seems to come exactly at 2000rpm - regardless of the road speed. The tyres are fairly cheap ones though.
    I 'undid' the airbox mod, and blasted some carb cleaner through the throttle body and it now seems less jerky on and off the throttle. Still a jumpy so and so in 1st and 2nd!
    Sep 2009
    Audley STAFFS
    ok, if thats made it a bit better, I SUGGEST REDEX INJECTOR CLEANER,, I used it every fill up for the first few tank fulls and did seem to smooth things out, now use it every third fill or so.
    Durham
    I haven't used Redex since the carburettor days! Will give that a shot in the next full tank. Cheers
  1. 1.8 vvti
    By veccy c in forum Tuning
    Last Post: 3rd April 2012, 12:51
  2. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  3. 1.8 VVTi (55)
    By don23 in forum Troubleshooting
    Last Post: 3rd October 2011, 11:33
  4. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  5. 1.8 vvti or not
    By surreyl31 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 23:30
