Results 1 to 10 of 21
Thread: help cant read german
    Regular Member signumT's Avatar
    grimsby
    Default help cant read german
    http://cgi.ebay.co.uk/CR-Powerbox-fu...QQcmdZViewItem
    these seem cheap anyone know if there any good
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Looks like a CR Green box in a different cover mate, same quoted outputs as the CR Green
    Regular Member Harry's Avatar
    Uxbridge, London
    from my limited german (!)
    Description of auction Small boxes, large effect! The engines of modern cars are steered by a computer, the so-called engine expensive equipment. Combustion engines bring more jeher the necessity since with itself to co-ordinate both the air/fuel mixture and the ignition on the respective operating condition of the engine. Already Henry Ford's model A made it for the driver possible by automatic controllers at the steering column to affect the ignition and the gasoline supply. Nowadays modern vehicles are equipped by the manufacturer almost exclusively with electronic engine management systems. Completely directly whether it concerns around a carburetor similar central injection or by far more effective multi-haven injection or around a Diesel injection and a load pressure control - all become of most modern rear-Tech - the engine expensive equipment steered. In the controller among other things characteristic diagrams are put down, which as a function of different parameters e.g. load and number of revolutions the injection amount regulate. All newer diesel engines with injecting electronics can be getunt therefore relatively easily electronically, by increasing the injection amount somewhat. The border is given and with our solution is not reached by maximum soot output. In the cylinders even still another enormous excess air is available which is sufficient around a increased injection amount to process with full load. Torque and achievement rise on to this excess air are used up. This is done via our external power boxes, which it optimizes the sensor signals in such a way that the on board computer in-regulates simply a increased injection amount. In other operational sequence like the engine characteristic diagrams and all relevant engine characteristic values are not intervened e.g. load pressure to remain on standard conditions. Adjustable achievement! Each MARK Electronics power box has an attitude of the achievement. The user has the possibility with the CRD Powerbox over a Adjustschraube, which is integrated in the box, of stopping its desired achievement. Plug & drive system! The offered CRD Powerbox is capable of of Plug & drive, i.e. the power box is already equipped with a special vehicle-specific wiring harness, with which the connection is made only by putting. Thus a fast and problem-free installation is ensured. Examples of vehicle-specific plugs Predivide those convincing: Larva in Germany, by the manufacturer the protective functions of the engine remain direct receive invisible assembly assembly in few minutes (detailed and illustrated guidance is with) of each layman to insert fast, arrearsless disassembly (e.g. to the customer service, leasing return or with the sales possible). Tuning remains also after controller updates e.g. with inspection. (with chip Tuning is usually overwritten the getunte file) to 1.0 L/100 less consumption adjustable increased output over integrated Adjustschraube increase of the terminal velocity no entry in the error memory of the board computer everything our products go through 100% a final test. In order to underline the high quality standard, you receive an extended guarantee on this power box from altogether 3 years. Use: The use is not permissible in the range of the StVzO. They offer here on an original Mark Electronics CRD Powerbox for OPEL vehicles with Common Rail technology, directly from the manufacturer. The CRD Powerbox convinces by enormous increased output, and a very high torque increase. The box is suitable for the following vehicles with Common Rail engine (see list). Please you indicate your motor vehicle type, year of construction, capacity and achievement after auction end or the key numbers (`zu 2` and ` to 3`) from your vehicle light. If your vehicle should not be listed, please you contact us or attendance our Shop.
    grimsby
    any good for the price???
    Uxbridge, London
    does seem very cheap.
    EVERYWHERE
    Ordered one,seem very friendly.Let you know how it goes on my V6.Agree with earlier post that power and torque figures are same as "CRD Green",which is a box that seems to 'agree' with the V6.Won't mess about with it too much though.Any improvement at that price is more than reasonable IMO.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Won't work, seen the amount of connectors :P
    JOKE!
    EVERYWHERE
    Quote Originally Posted by CDTi
    JOKE!
    Oh ****! I'll figure it out somehow.
    EVERYWHERE
    Received box (Friday),but with wrong connectors.Imformed them of this,but they say they don't have any to fit! So they gave me a 50% refund!
    All I need to do now is either splice into my own loom (there goes the warranty) or fit correct connectors.Any ideas?
    Here, there and every where!
    Send it back for a full refund m8, why should you have to settle for a discount for something you are going to sort out yourself
    You could order one of THESE
    Cheaper and it does work properly
  1. Very expensive german lhd german vectra
    By vectra ste in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 17:36
  2. Anyone speak or even better... read German?
    By n_hudson in forum The 'Off Topic' room
    Last Post: 27th January 2009, 20:38
  3. Help can anybody read german?????
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 23:20
  4. can anyone read german
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2005, 19:19
