Thread: wtf?? EML
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default wtf?? EML
    When i switch the ignition on the engine management light comes on but when i start the engine it goes straight out! what does this mean?
    Thanks,
    Rich
    Jan 2006
    Dalriada
    I think it means that a fault has been logged in the ecu but im sure someone will know for definate
    i had this when i plugged a tuning box onto mine for the first time...
    Devon
    Engine : 2.0 Turbo
    is it possible to clear this?
    Regular Member Harry's Avatar
    Uxbridge, London
    i don't think it's a problem unless it stays on.
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    When you turn the Ignition on the EML illuminates as the ECU self checks, it will go out when engine started if all is OK
    Jan 2006
    Dalriada
    Quote Originally Posted by Vectramodz
    Thanks,
    Rich
    Is it the car symbol with the spanner in the roof??
    Sorry should of asked first time round, if so it has logged a fault. If its the small EML it does as Robbie says..
    Devon
    Engine : 2.0 Turbo
    sorry its the car with a spanner through it
    Admin plasma's Avatar
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    Its logged a fault but not serious enuff to stop it letting you drive as per normal. Need a tech2 unfortunately to read it off
    Regular Member SirGSi's Avatar
    England
    Mine's done this a few times.
    It first appeared when trying to start the car and didn't fire up.
    It goes after about x amount of successful starts (about 2 weeks for me).
    The dealers couldn't find anything wrong when I took it in.
    HTH
    Grant.
    Devon
    Engine : 2.0 Turbo
    All sorted now thanks guys... i disconnected the battery this morning for about 30mins and when i re-connected again the symbol was gone
