Thread: steering rack arms
    Aug 2010
    Blackwood
    Default steering rack arms
    hi guys,
    mate of mine just changes my brakes for me.i asked him to check the ball joints cos the mot is on the weekend. he said theres play in the streeing rack arms but its a garage job cos hes never changed them.
    been quoted £110 for both sides if the gaters are still in good condition.
    anyone know if this is cheap/expensive/avarage?
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I paid £100 back in march for both of mine to be done. Just make sure the £110 includes tracking, as it will need it.
    Quote Originally Posted by richje100 View Post
    hi guys,
    thats not a bad price but to be honest if your mate can change brakes he should be able to do inner tie rods
    all he has to do is
    undo track rod end
    undo steering gaitor clip at steering rack end
    when he does this he will see a ball with a nut shape on it
    unscrew this nut shape and the inner tie rod and track rod end will come out
    remove track rod end from inner tie rod , counting the turns it takes to unscrew it
    remove tie rod gaitor
    fit gaitor to new tie rod
    screw on locking nut from track rod end then screw on track rod end ( best to replace these aswell saves a job later on ) the same amount of turns it took to take it off
    screw inner tie rod back onto steering rack
    fill gaitor with grease
    re attech gaitor
    re attach track rod end
    get tracking sorted
    job done
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    bit of a pain to get the inners undone if your on your back on the floor tho.
    but a job you can do yourself..... just undue with stilsons !
    al.
    Quote Originally Posted by Al 22 dti View Post
    al.
    your not wrong al that nut can be a right pain
  1. Steering rack arms?????
    By veclee in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 02:42
  2. Steering arms / tie rods
    By plasma in forum General Motoring Chat
    Last Post: 13th February 2013, 22:32
  3. steering rack
    By kevin hunter in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2008, 20:25
  4. signum steering arms
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 20:51
  5. steering arms
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 21:48
zafira play in steering rack inner joint
