Results 1 to 10 of 17
Thread: Im going to view a Vectra 2.2 SRI! any major faults to look for?
    May 2011
    liverpool
    Question Im going to view a Vectra 2.2 SRI! any major faults to look for?
    Ive posted on here last month as im looking for a black 2.2 sri. Im not having much luck but i have found a private seller "2003 2.2 Sri" for £2300 with part service history and 12 months mot. Its also just been serviced. Its done around 56,000 miles.
    Its private and very well priced.
    Have they all got a faulty fuel pump/regulator problem that the 2.2's have been accused of on watchdog?
    http://www.bbc.co.uk/blogs/watchdog/...ddenly_lo.html
    and will i be able to tell if he has had it replaced?
    shall i buy it if he claims that there has never been any faults of that kind? as i dont want it happening while im driving it lol.
    Any other major things to check if they have been done? or things to look for in the engine on start up? Its will be a chain wont it? so i should check for rattles from it?
    Im a newb with cars as i have only been driving a year and only owned 2 Focus's and was wondering what faults that Vectra's with that mileage and age can occur and what should have been done by him with it only having part service history.
    thanks for any info.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    On a 2003 Vectra it will be the Z22SE engine which doesn't suffer with the fuel regulator problems.
    As long as it's been looked after, the Z22SE engine is pretty bulletproof, although a little under powered in standard form. Check for a rattle on start up (or under load) which may indicate the chain needing changing. Check for blue smoke under the same conditions too.
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Check the hp fuel pump mate if it's a siemans sticker then it's the old type if it says continental then it's been changed. To Change one of these is around £300
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Shouldn't need to on the Z22SE, it's not a major problem with them like on the Z22YH (2.2 Direct)
    May 2011
    liverpool
    Quote Originally Posted by Ian-Highlander View Post
    i was wondering if it was just the 2.2 Direct that had the problem with the fuel pump reg. I certainly don't want to be paying out for things like that. There is no other major things is there if the chain is ok and there is no fuel pump problems??
    I only know the basics of giving it a good test drive and going up and down the gears. checking the brake's and clutch etc.
    How long do clutch's normally last in Vectra's would that be due one if its not done?
    Should it have had regualar oil changes aswell? as there will only be part service history.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Are you VXR Enough
    13 Post(s)
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Quote Originally Posted by David P View Post
    no one can tell you how long a clutch can last if they do its all bull ti be honest as they mite have hammed it to an inch of its life you will never no............be like if i sold mine i could say anything its up to you to 100% with it................get a diesel much nicer lol
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Yeah diesels, DMf failure, egr fails, dpf issues etc etc, petrol all the way for me
    Sep 2010
    in a box
    Quote Originally Posted by triple595 View Post
    dmf petrol too mate erg not allways mate keep it clean dpf auto and signums so next?!?!
    petrol fuel pump going coils seem to allways **** up less miles per gal
    so they all **** up so its swings and roundabouts mate
    ill never have a petrol unless its a weekend car
  1. Vectra GSI 2004 Major Drama
    By nickgibo in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 10:09
  2. Vectra C 1.8 2002 CIM and ECU Faults
    By Dougie in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2011, 13:41
  3. Vectra C 1.8 SRI (faults?)
    By daddycool in forum Engine & Drivetrain
    Last Post: 14th June 2011, 12:08
  4. loads of faults on my vectra - HELP
    By molloy in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 20:44
  5. vectra- problems or common faults?
    By fergusix in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2008, 16:48
