Results 1 to 10 of 11
Thread: little drl led mod in progress, bit of advice
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default little drl led mod in progress, bit of advice
    hi all, currently collecting up littlebits and pieces for a DRL mod im planning. witch is totally different to the standerd block things you currently get of the bay.
    currently got a selection a relays, leds, wire, connectors and such like
    but am having issues on how to have the set up ive designed to run.
    should i have them
    1 - work as soon as the car is on and stay on all the time.
    2 - work only on there own "go out when sidelights are on"
    3 - work with side lights only.
    4 - work with dip beam only.
    cheers for any input, Tim
    Regular Member Ben_'s Avatar
    Audiville, WM
    i would say wire them up as DRL's are supposed to be so on when nothing else is IMO
    Regular Member russ1969's Avatar
    Worthing
    Thumbs up
    Option 1 in my opinion
    Nov 2010
    BRECHIN
    not trying to cause myself plod trouble, so if that is the way they are ment to run then i think i will do it that way.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Option 2 as this is what DRL's are meant to do
    Nov 2010
    BRECHIN
    think a poll is in order!
    Aug 2010
    Stoke on Trent
    I always thought that DRL's should only be on when no other lights are lit which is easy to do... wire the DRL's to ignition live then feed the power to the DRL's via the normally closed contacts of a relaxed relay which itself if activated by a feed off the sidelights so when the sidelights are on the relay is activated and opens the normally closed contacts which breaks the feed to the DRL's turning them off..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the correct legal way is "option 2"
    Nov 2010
    BRECHIN
    Quote Originally Posted by jimbojetset View Post
    exactly how i was gonna do it
    edit!!
    just realised ive got 3 normally open relays........... doh!
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by TimTay View Post
  1. Progress On My Car...
    By OllyT in forum Styling
    Last Post: 17th November 2011, 18:38
  2. vec progress so far
    By yadziyad in forum Styling
    Last Post: 4th October 2009, 21:05
  3. My Vectra progress...
    By danBoy in forum Quick Photo Album
    Last Post: 26th December 2007, 12:29
  4. Progress Rating
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 01:11
  5. Progress?
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2006, 23:08
