Results 1 to 10 of 16
Thread: Cat Or Lambda
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Cat Or Lambda
    I Already Got A Thread Up That I Failed My M.O.T Due To Emissions...
    Cheapest Cat I Can Find Is £220..Plus Lambdas..We Are Talking £330 All In...
    Whats The Chances Of It Just Being Lambda`s That Are ****** Rather Than The Cat ?
    Got Told That When Removing Lambda`s From The Cat They Usually Break
    If I Go Down The New Cat/Lambda`s Thats My Piggy Bank Well And Truly Burst
    Codes That Were Showing Up Were
    P0420
    P0170
    P0420 And Has A "P" After It
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    if heated and removed correctly they dont break. just when folk go gung ho. 9 years of fitting exhausts and tyres never had 1 break.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Think the issue with them is they can take the threaded insert, out of the cat, with them when they are removed Tam, but as Tim say heating them should prevent this. I would do the lambdas first then and only then think about the cat.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think the issue you have is more related to the MAF, when this goes wrong the car over fuels resulting in the Lamba on the Cat being burnt out and emissions issues.
    Might be worth spraying the MAF with some carb cleaner to give it a clean.
    Have you got a way of swapping parts with another 1.8 owner?
    Also only buy geniune GM parts or OEM as there are some cheap parts out there which will cause you more issues
    Aug 2010
    Dundee-Motherwell
    Just In..******* ******* Down With Rain Oot There
    Been On My Wanders...Tried To Find Oot If It Was Cat/Lambda..But To No Avail...
    So Had Enough...Vec Could Very Well Be Going Once I Finally Get A Ticket On It...
    Ordered 2 Sensors And Cat...Pick Them Up Tomorrow...
    And Thats My Pocket £400 Lighter..Got A Guy Fitting It For Me Friday For £50...Would Give It A Go Myself But Well And Truly ****** Off
    Coz If I Got A Bolt That Snapped Or Refused To Budge Or Summit..Would Probably Launch Ratchet Through Windy
    Nov 2010
    BRECHIN
    be a fool not to put the lambdas in first to see if that sorts it man. like said its throwing up the same faults as my inlaws and it was only 1 lambda.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    my monies still on the MAF as I had the same issue, I really would try that first before anything else. Hopefully the sensors are just showing incorrect readings due to overfueling rather than being faulty. If you fit new sensors and the MAF is faulty they will just damage the sensors again or throw up the same fault code.
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by TimTay View Post
    Think I Will Got Get Sensors 1st Then And Bang Them In...But Are They Gonna Cure My Emissions Problem ?
    Quote Originally Posted by merikiito View Post
    I Only Noticed The P0170 Code Yesterday...That Aint Been There Long...Other 2 Keep Coming Up..Will Try MAF With Carb Cleaner As Well
    Nov 2010
    BRECHIN
    thats the whole point of them! there not there for show lol
    0170 can be caused by several things 1 being faulty lambdas
    if i was a betting man the rear sensor is all you will need! lee gsi was saying the same so did someone else i think!
    Aug 2010
    Dundee-Motherwell
    Will Try Both Sensors Before The CAT Then Mate
    Cross You Fingers And Your Goolies For Me
    So When They Diddy`s At Kwikfit Said CAT Was ******..They Are At The Madam ?
  1. Intermittent Lambda ?
    By JagRigger in forum Engine & Drivetrain
    Last Post: 6th January 2013, 08:11
  2. Lambda sensors...
    By nikroc in forum Engine & Drivetrain
    Last Post: 29th November 2012, 21:56
  3. EML 2.0T Lambda or CAT
    By a1ant in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:53
  4. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
