Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: PC problem
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Default PC problem
    My sons PC has developed a problem when you press the power switch unit fires up and fan comes on full blast but there is no screen display whatsoever anyone any ideas without getting to technical ( yeah i know its Knackered ) before someone says it
    Chesterfield
    Vehicle : SRI
    Trim : XP1
    Engine : 1.9 CDTI 150
    Mileage : 86000
    Quote Originally Posted by signumboy View Post
    what is the make and model of the pc..... if its Dell its a system board fault and the capacitors on the board need replaceing... common fault with all Dell.
    Sep 2009
    Glasgow
    check and reseat graphics card.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    does the pc run onboard graphics or a seperate card?..on board and the connections are all together in one place,like a rectangle.
    Seperate card and it will be lower down the case in a single 'bay'..
    If you got both you will need to get into the systems bios and change the option from onboard to pci or vice versa..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If nothing is displaying on the screen then I would say graphics card or (unlikely though) there has been a fatal overvoltage in the motherboard and has destroyed components.
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by jobsagudun View Post
    Yeah it is a Dell Dimension C521 i have nothing on the screen whatsoever
    norfolk
    i would say power supply unit... although it still starting and putting power through, it may not be enough! quite common on pc's, see it all the time! antoher possibility is ram or graphics!
    Bristol
    dell have a quirk. Unplug the computer remove the motherboard battery and leave for 24 hours to let mother board reset to default. I done this one and it work fine. if this does not work It may be you CPU.
    May 2011
    bispham, blackpool
    its a AMD ATHLON so odds on removing the battery will work just keep it out for a hour or so i normanly do it for 10 mins when their in for repairs make sure you unplug it from mains first
    also why you have battery out take memory out and give the memory slots a blow with a can of air i use to have a dimension 5000 and every few mth use to do the same thing and always memory was dusty also when you put the memory back put one stick in plug it back in and try if it switches on unplug then put 2nd in try it etc etc this way if theirs any problem with any of the memory you will know which stick has the problem
    also why you have it open give every where a blow to get rid of any dust near fans etc as the better it can breath the better it will run
    good luck you should be fine you have a dell computer dont get many of these in to repair as they dont go wrong much
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by 6009tristanb View Post
    Ok ill give that a whirl ...i have blown all the dust out from all the fans as i thought that was the problem myself ...will let you know fingers crossed
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
