Thread: noisey 2.2 dti engine
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default noisey 2.2 dti engine
    my dti is very noisey very noticeable on take over and at 3k rev's , its like a tickity clatirey noise could it possible be a timming chain tensioner or guide
    i have checked for blow out's etc.its been like this for months i have even changed the oil to 10w40 and tried 2 stroke with no difference what so ever , it really sounds like a tractor and is a bit annoying when you hit traffic when in a town out for a sunday drive
    Regular Member Gazz's Avatar
    May 2011
    N.Ireland
    You sure its def the engine? one of things you should maybe check is the exhaust line? might be a small crack and when you go over the 3000rpm its blowing the gas threw one of the lines
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    yes lad checked the exhaust , i dont need to rev it to hear it
    May 2011
    N.Ireland
    if no one gets back to you with any more bright ideas ill ask my mechanic tomorrow as my 2.2DTi Siggy is going in!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not to panick you mate but get it checked asap. Sounds like one of the symptoms of a cracked crankshaft. Better to check now that for the crank to go altogether and do major damage
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Ah ours should of cracked twice now already
    Change the fuel filter mate and give it a good service. My mate had a similar problem on his Vec B 2.0DTi and it turned out to be a blown gasket on the inlet manifold. It ran like a dream after he got that changed.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You may joke but there have been three instances of broken crankshafts on here this year. two 2.0dtis and one 2.2dti. It's not much hassle to check but it's alot of hassle if you go changing fuel filters and then the crankshaft breaks
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    john its been like this for the past 12000 mile and i had a new outer crank seal put on 2 weeks ago , the noise seems to from the air box side of the engine thats why im thinking chain tensioneer i had the top 1 out which looked ok but i have never seen a new 1 to compare im goin to get the bottom 1 out to have look
    celes which inlet gasket do i change , i dont see any signs of a blow out around the manifold
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's the bottom gasket my mate got changed (under the swirl flaps). No signs of a blow out, but sounded extremely tappy under load especially once on revs, not to mention the mpg that plummeted...
  1. noisey shocks?
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2013, 21:02
  2. Replies: 25
    Last Post: 4th August 2011, 21:19
  3. Noisey air con fan
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 08:10
  4. My 55 plate vectra engine sounds alittle noisey then usual
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2009, 22:29
  5. Advice - noisey engine
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 12:15
