Thread: power steering
    Nov 2009
    bury
    Default power steering
    can any one help, power steering failed today, error code u2111, any ideas please...
    EDINBURGH
    Did you get it sorted, i have started to get a intermittent u2111 fault code since i changed my flywheel a few week back,
    I know i strained the cable between bottom of power steering reservoir and the steering rack when changing flywheel although i have tested cable and it's fine
    kenny
    EDINBURGH
    Some more info
    if i clear all faults then all faults below clear except
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    then when i re read fault codes they all come back again, so i'm thinking i am looking for a bad connection some where?
    DIAGNOSTIC REPORT:
    OP-COM 090714
    Ursu
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0014
    VIN: xxxxxxxxxxxxxxxx
    Part Number:13204147
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 070606
    Number of stored fault codes: 1
    (00) - Present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x1318
    System name: Z19DTH
    VIN:xxxxxxxxxxxxxxxxx
    Hardware number:81012869
    Part Number:55566276
    Software version number: HJKMS210_S
    System description: BOSCH0100
    Type approval number: B07013
    System description: 0x00007098
    Alpha code: HA
    No fault codes stored.
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x6003
    Hardware number:0
    Part Number:12773671
    Software version number: 00C2E92D
    System name: ABS 430 NG
    Alpha code: BS
    U2103 - <Unknown DTC>
    (00) - Present
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x1104
    Part Number:13193056
    Software version number: 4.46 29/06
    System description: VDO 0400
    Alpha code: RT
    Manufacturing date: 070627
    (7F) - Present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0102
    VIN: xxxxxxxxxxxxxx
    Part Number:13186947
    Software version number: 0C0D4B11
    System description: 0x41533639343753303130353236373620
    Alpha code: KN
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0209
    VIN: xxxxxxxxxxxxxx
    Part Number:13193590
    Software version number: D02D11 49041605
    System description: TEMIC04
    System description: 0x20202020202020303031393837343939
    Alpha code: NF
    Manufacturing date: 000700060200
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0105
    VIN: xxxxxxxxxxxxxx
    Part Number:13205774
    Software version number: 00000FA1
    System name: REC
    System description: LEAR 0400
    Alpha code: FP
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0105
    VIN: xxxxxxxxxxxxxx
    Part Number:13240245
    System name: UEC
    Alpha code: JG
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0106
    VIN: xxxxxxxxxxxxxx
    Part Number:13193368
    Software version number: OP1D 193000
    System description: SIEM 0401
    Alpha code: JQ
    Manufacturing date: 225070
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0105
    VIN: xxxxxxxxxxxxxx
    Part Number:13193369
    Software version number: OP1D 192000
    Alpha code: JR
    Manufacturing date: 816070
    Source Address: EHU
    Source Address: 0x00000241
    Identifier: 0x0205
    Hardware number:13233835
    Part Number:13233926
    Software version number: 06.19/-----
    System name: CD 30
    System description: BOSCH0400
    Alpha code: SE
    Manufacturing date: 20070627
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1101
    Hardware number:13275084
    Part Number:13275272
    Software version number: 7082-/-----
    System name: BID Epsilon
    System description: BORG 0400
    Alpha code: AX
    Manufacturing date: 20070614
    U2139 - Invalid Data from CIM (Steering Column Module)
    (71) - Present
    EDINBURGH
    Got my problem sorted and it goes back to me changing flywheel
    when i reconnected all the positive leads to connecting block on side of battery cover i dropped 1 of the nuts but as terminal was spare i didnt bother too much.
    what was happening was when i put battery cover lid down it was pushing against 1 of positive cables in connecting block enough to lose the connect on the post with no nut fitted, put a new nut on and all codes are clear and car working fine.
    kenny
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
error code U2111-00
