Results 1 to 10 of 16
Thread: knocking from front end
    Regular Member danny_n's Avatar
    Feb 2011
    wakefield
    Default knocking from front end
    i'm hoping you guys can help because i'm a bit stumped;
    my vectra 1.9cdti has developed a knocking from the front passenger side, i first noticed it a few days ago and has got worse since then.
    after searching on here i found it could be the drop links, i've changed the front pair tonight to no avail- knocking still bad as ever.
    after looking again the only thing that shows any sign of movement is the brake pads, they seem to be able to move within the caliper, not sure if this is the cause
    any ideas guys??
    any help appreciated,
    danny
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you checked the springs fella they are prone to snapping
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is there any play in the wheel? Possibly bearing, track rod end, ball joint, or spring. Could be brake pads, does it knock when you are braking?
    Feb 2011
    wakefield
    yeah i've checked the spring and its fine
    Quote Originally Posted by tony-1977 View Post
    when i had the car jacked up, i held the wheel at 9 and 3 o'clock and tried to move it and it wouldn't budge so that rules out track rod end i suppose
    i tried running over rough roads and braking but it was quite tricky, dont think it knocked when i braked but i cant be sure - the road might not have been that bad at that point
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Was the spring under load when you checked it?...
    Feb 2011
    wakefield
    Quote Originally Posted by nikroc View Post
    erm no ... i had the wheel off but the suspension was hanging as it would normally
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    just meant was the check visual or were you able to feel it and move it around?..probably sounds stupid but i know what i mean...
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    might be the top mount they dry out and wear a flat spot squirt with wd40 in side the engine bay see if it goes if it does go its them and they need changing as the noise will come back
    Sodding Typical on Sea
    Have you had a look at the ARB bushes? they can give a clunk or three. The wishbone bushes are generally sound unless the bottom ball joint has some give of course.
    Feb 2011
    wakefield
    yes i was able to pull and tug on it, no movement
    Quote Originally Posted by markj23 View Post
    thanks, will try this
    Quote Originally Posted by Derek Mc View Post
    yeah i looked at the ARB bushes and they looked fine, my car is only an 07 plate and most of the suspension components looked spot on, except for the drop links that i have now replaced
  1. Knocking at Front......... Help
    By johnny1983 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2012, 17:46
  2. Knocking from front
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2011, 18:51
  3. Knocking at front
    By NikNakNok in forum Engine & Drivetrain
    Last Post: 7th June 2010, 12:09
  4. knocking front end
    By VECTRA HEAD in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 20:24
  5. Knocking Front O/S
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 19:40
opel astra squirty sound in engine
