Thread: diesel knock with reconditioned injectors fitted
    Regular Member pugs,signum's Avatar
    swansea
    Default diesel knock with reconditioned injectors fitted
    Hi,
    Im wondering if anyone can shed some light on the above issue?
    I had a terrible judder under 1500rpm and mpg was down, put the car into a garage and they done a leak off test that shown injector 4 was shot and number 1 was close to shot, suggested i change injector 4 first and see what happens, so bought reconditioned injector and had it fitted, garage rang and said they all need doing as it sounds like a bag of nails.
    I picked the car up and it was knocking like mad so decided to replace all the injectors, put car back into garage and had the rest fitted, he said its still knocking a bit but not as much also said it would need a good run so the car gets used to new figures and it should settle itself.
    Ran it for over 60 miles and it didn't improve so went back to garage and the guy gave me my key back and asked if everythings ok? shaking my head nnnooooo its still knocking, he checked it over and put a flush though the fuel tank and told me to kepp running it as it should settle. (haven't paid the guy for doing the job yet)
    went to another garage whom i can trust as its my fathers local and never given a problem, told him what happend and he says the original guy aint lieing to me and its normal that a diesel will have a diesel knock after having new injectors! also said that may be able to alter the preasure in the common rail so he said he'd check on his disc on the pc over the weekend and let me know, so he said the poundage (not sure how to spell lol) can be checked on it but vauxhall could do this and he couldn't aslo it statted on the disc that it will give a diesel knock and will settle.
    has anyone been through this and found the car has settled after a few weeks?
    Does anyone know anything about checking the poundage in the common rail and if it can be adjusted?
    Hope i aint bored too many people with this lol.
    Wales
    Have the new injectors been coded to the car?
    swansea
    Yes sorry I should of said they have been coded, also if anyone is wondering it's a 1.9cdti (z19dth) engine
    Engine : 1.9 CDTi
    Did they reset them?
    swansea
    Eek
    Quote Originally Posted by lee gsi View Post
    Reset them????? They are reconditioned and been programed to the car. They guy who did them worked for vauxhall for 15 years working his way up through machanics levels so would of thought he knows what he's doing.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I had the displeasure of having injectors replaced twice and in both occasions there was a slight diesel knock. Nothing like you're describing though...all settled within 10 miles.
  1. Increased diesel knock
    By simon987 in forum Engine & Drivetrain
    Last Post: 11th April 2013, 19:47
  2. Diesel Knock and no compression on No.4
    By skip85 in forum Engine & Drivetrain
    Last Post: 10th October 2011, 21:51
  3. DIesel Knock
    By Si-SRI in forum Engine & Drivetrain
    Last Post: 9th June 2011, 12:47
  4. Diesel pump knock
    By ads3 in forum Engine & Drivetrain
    Last Post: 8th June 2011, 18:22
  5. diesel injectors
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2010, 10:02
vectra c injectors knocking
vauxhall vectra 1.9 cdti diesel knock
z19dth injector knocking
