Results 1 to 10 of 11
Thread: vectra cdti noise on clutch
    Aug 2010
    cheshire
    Default vectra cdti noise on clutch
    can anybody help i have a 05 cdti 150 when i start the car from cold it ticks over perfect but as soon as i put the clutch in it makes a awful knocking/rattle noise then if i release the clutch pedal it stops it only does it when cold once warm its ok, any help would be appreciated thanks. ps car runs fine and clutch not slipping in any way.
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Sounds like Daul Mass Flywheel (DMF), does it do it only in neutral?
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Dual mass flywheel, do a search on here it's a very common problem
    Jul 2010
    Skipton
    Quote Originally Posted by benholden2010 View Post
    Mine went although it had done 110k. I had it done via the dealer for £900. You can get it cheaper non dealer though. They also replace the clutch at the same time
    Aug 2010
    cheshire
    thanks for the replies i will check tomorrow if it only does it in neutral, the car has only done 35,000 is this common
    Jul 2010
    Skipton
    Quote Originally Posted by hitcho View Post
    If you use the search button for Dual mass it should bring up countless threads on this. As far as I am aware it should not have given up the ghost at only 35k.
    Aug 2010
    cheshire
    thanks oneminutesilence i did a search and people are putting that they have had this problem and just left it will this be ok till i can get the money together or trade it in..lol
    Regular Member coooky's Avatar
    May 2011
    washington
    Luk clutch and Sachs DMF £450 on e-bay
    when i rev mine it makes the the noise then when i slightly press the clutch pedal you can hear it change,they say cars have been driven 90k with them failed
    my thread here when i asked
    http://www.vectra-c.com/forum/showthread.php?t=140299
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    If it makes a noise with the clutch pedal released but not with it depressed is this gearbox input shaft bearings? Ta
    Feb 2011
    London
    Quote Originally Posted by Gazza36 View Post
    Did you ever get an answer for this? Mine only makes a noise on tickover. As soon as the clutch is down it's smooth and quiet again.
  1. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  2. vectra 1.9cdti clutch noise?????
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 5th January 2010, 15:47
  3. CDTI 150 Clutch noise. DIagnosis required
    By 12345 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 18:35
  4. 1.9 cdti clutch noise?
    By joe2187 in forum Engine & Drivetrain
    Last Post: 10th October 2008, 21:03
  5. 05 Plate - 150 CDTi Clutch Noise
    By iRocco in forum Engine & Drivetrain
    Last Post: 23rd August 2008, 17:25
when i press the clutch it makes noise vectra
vectra c cdti clutch rattle
