Thread: Problem with amplifier blowing fuse
    Aug 2009
    Hull
    Default Problem with amplifier blowing fuse
    I had a profesisonal install of an 800w Orion amp and sub in my Vectra 2.2 Dti. It has been running last 2 years with no issues until one day a few months ago it stopped working.
    I discovered the fuse on the power lead in the engine bay had blown. I replaced it with the same ohm fuse and when I turned the ignition on this fuse popped as well.
    I have checked the earth is secure and no other wires are touching each other on the amp connections.
    Both fuses on the outside of the amp look ok. Has anyone got any idea what could be wrong?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Most likely the main power cable has worn somewhere against the chassis and is touching metal.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Yep, you need to check the full length of the power cable and look in detail at every connection.
    Aug 2009
    Hull
    Many thanks for the advice. I will investigate as suggested.
  1. cigarette lighter blowing a fuse
    By ciderman in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 22:42
  2. Heated seat blowing fuse
    By karlmax27 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 14:21
  3. o2 sensor fuse keeps blowing
    By michael0304 in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 01:27
  4. My amp fuse keeps blowing?
    By sirnapper in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2009, 20:41
  5. Headlight washer system fuse keeps blowing
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:58
