Thread: new engine
    Regular Member matt.d's Avatar
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    Engine : 1.8 16v petrol
    Default new engine
    hi there a friend of mine has a 1.8 zafira which had a new engine fitted the problem is its throwing up fault codes going into limp mode throttle control promlems etc etc now i was thinking the second hand engine she had fiitted is not coded to the ecu and i reckon if i reset the fault codes and reset the ecu would this remedy the probem i have the obd2 can diagnostics tool i need a quick reponse to this one guys and gals as the friend would be doing the reset regardless
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Z18XE(16v) or Z18XER(vvt)? Nothing to match code wise on the z18xe but not sure about xer.
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    z18xe 16v
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Was the engine heard running prior to purchase? Just double check the wiring, is the MAF connected, both lambdas are connected(there is one right under the front pipe at the back of the engine, if using the coil pack supplied with the engine try swapping over the one from the old engine.
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    all sensors brand new cat the lot i reckon ecu on the blink run and re-set fault codes and still they keep popping up apparently the ecu is a very common fault on these due to where they are placed too near the engine they cant get rid of any heat hence fail not my car anyway im vectra 100% vectra c so b!!!!!!cks to her
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    I Am Lookin For A Cat/Lambda Sensors
    Regular Member benny's Avatar
    Feb 2006
    dudley
    is it the right engine that has been fitted see this lots ...have they fitted a x18xe1 wich is kindathe same looking lump but is different .....
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    What fault codes are coming up
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    not sure about engine and the friend is going for ecu regardless what i say thanks for your interest
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
