Results 1 to 10 of 23
Thread: What size disc's
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default What size disc's
    my car is a vectra 57plate 2.0 turbo what size discs does this have 285mm or 314mm cos the vx dealer says its a choice of 2
    thanks guys
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are you VXR Enough
    13 Post(s)
    302
    hes saying if the car runs 19'wheels which mine has then it will be the 314mm
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's got nothing to do with wheel size. It's all down to engine size
    302mm front 292mm rear
    Only the V6 non VXRs had 314s standard
    Are you VXR Enough
    13 Post(s)
    hes put the chassis no in the computer at the vx dealership and it comes up with either 285mm or 314 mm but i thought turbos ran 302 mm and the V6's ran 314mm
    Aug 2010
    Leeds
    Measure it.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You can tell if it's 314's as the calipers are completly different to the 302.
    The 314's have a square bit on the anti rattle spring, the 302s have a triangle
    VX Never fitted anything other than 302s to the 2.0t
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by Bigtee View Post
    Measure it.
    measure it how
    Are you VXR Enough
    13 Post(s)
    like these
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Mmmm they are 100% not 314's then. They must have fitted the wire type spring to the later 302's
    That is the front isn't it?
  1. what size are my disc's?
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 16:19
  2. scratched disc's
    By markj23 in forum Games Room
    Last Post: 19th February 2011, 23:29
  3. What size disc's?
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2009, 18:31
  4. What disc's do you have?
    By Leemarksmith in forum Handling & Braking
    Last Post: 27th June 2008, 22:00
  5. 314 disc's and pads
    By chrisgettings in forum Handling & Braking
    Last Post: 23rd January 2008, 18:26
