Thread: More engine help please
    Jun 2011
    United Kingdom
    Default More engine help please
    Hi guys, well, after having found oil in my water, ive flushed it all through but its come straight back again so im guessing the head gasket is gone ?
    Also the engine management light has just come on, and it seemed to take a while to start.
    I was also having trouble with idleing and flat spots so decided to try clean the AFM and it was fine until today, could this have also caused the management light to come on ?
    Checked for codes and one of them that popped up was 0303 - misfire detected on cylinder 3. Now what would cause this ? Its not noticable at all when driving ?
    Thanks very much
    Jul 2009
    The Rift, Cardiff
    The missfire is likely to be a failed spark plug. What were the other codes?
    Jun 2011
    United Kingdom
    Hiya mate, the other code was P0170 Fuel Trim Malfunction (Bank 1)
    I thought it may have been the air flow meter with that code so I cleaned it out and it seemed fine all last night but now today it seemed to struggle to start and the eml is always on now, and it wasnt before ?
    Thanks very much
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    does the eml stay on after starting
    Jun 2011
    United Kingdom
    Yes it does now mate, it didnt do until today even though it still showed the same fault codes.
    Thanks very much
    Jun 2011
    United Kingdom
    Ok guys, well Ive had a mobile mechanic call round tonight as I didnt really want to drive it, he said the head gasket is fine !
    So what else could cause all this oil to get into my header tank ?
    The car doesnt smoke, doesnt loose water or oil, does not pressurize in the header tank, there is no 'mayo' on the oil filler cap or dipstick either.
    Ive flushed it all out and cleaned the bottle but the oil is back in the bottle again today so it must be coming from somewhere lol.
    Thanks very much
    May 2006
    Mansfield
    What engine is it, do you know if you have an oil cooler ?
    SJ
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
