Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Better Dip Beam
  1. #11
    Sodding Typical on Sea
    I have tried a few upgraded bulbs but went HID and last winter was just so much better than before. I also had the beam checked and made sure I didn't dazzle myself when I did a drive by from my wifes car but the light quality is just awesome.
    They are a very easy kit to fit the hardest part is drilling a hole in the plastic cap, which itself is a very simple task, the rest is simply plug'n'play
  2. #12
    Feb 2011
    Selby
    The problem is as Ian T said, the beam pattern is simply way too low. Fitting brighter lights (eg HID) really isn't addressing the actual problem, just relying on the extra light that's scattered by the lens to illuminate the area outside the defined projector pattern.
    Raising the headlight aim so it's just on the legal limit (then making sure the headlight aim switch on the dashboard is dropped a little for the MOT) is about the best you can do.
  3. #13
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    As Grumpy mentioned HIDs are infact ilegal if not self leveling or you dont have headlight washers
  4. #14
    13 Post(s)
    Quote Originally Posted by rich r View Post
    What twaddle. The beam pattern will be the same regardless whether it's a halogen bulb, or HID bulb. There will be no extra beam scatter from a HID bulb if used in headlights that have projector lenses.
  5. #15
    Regular Member JohnSH8892's Avatar
    Jun 2011
    Cambridge
    Quote Originally Posted by farley2708 View Post
    hi stevie,forget about the osrams etc,get yourself a set of HID's,then adjust them using Duncans method on here
    Does anyone have a link to "Duncans Method", can't seem to locate it.
  6. #16
    Regular Member coldo's Avatar
    Scotland
    what is Duncans Method...? I can't find a link to it...
  7. #17
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Basicaly park in front of a wall with your lights on and the leveler at its highest. mark where your beam level is on the wall. Move your lights to possion 2 then adjust your lights so they are back at the original level. This will now mean your level 1 is higher. Hope this makes sense. Or most garages will adjust lights for free. So just ask them to set it to the highest legal level
  8. #18
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    No HID's won't affect beam pattern, but most people can't be bothered with the potential hassle of MOT's next year. Yes they pass just now, but just now isn't under the new, tighter rules.
  9. #19
    Jun 2011
    Cambridge
    Quote Originally Posted by s_zigmond View Post
    Makes sense.
    Thanks Zigmond
  10. #20
    13 Post(s)
    Quote Originally Posted by JohnSH8892 View Post
    Quote Originally Posted by coldo View Post
    Here it is.
    http://www.vectra-c.com/forum/showthread.php?t=33655
    Says for preface lift lights, but I can vouch that it also works for facelift lights as well. I also used the same method on an Astra-G that had the lights set too low.
  1. Hid beam
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 13:16
  2. low beam problem
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 09:06
  3. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  4. Dip Beam
    By dc6839 in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 17:53
  5. Low beam
    Last Post: 30th December 2008, 19:31
best way to improve dipped beam on a vectra
