Results 1 to 10 of 13
Thread: P0650 mil control circuit malfunction code
    Jun 2011
    manchester uk
    Default P0650 mil control circuit malfunction code
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    Hi i am getting the above code when plugging in to the diagnostics on my 05 plate facelift 1.9 cdti 150ps, i am getting the yellow car with spanner on starting the car (ps the car start and runs fine) the spanner and car then either goes off or stays for a mile or so before going out and can return during the journey, has anyone else had experience of the above and how did you sort it?
    on searching the forum and net i can find the below possibles
    glow plugs
    dry joint on instrument cluster
    i have removed the cluster for a look (and a wiggle of the connector) but the fault remains.
    any ideas??
    ps i do not have the engine management yellow engine showing when the car and spanner are showing.
    simon
    (new member and first post)
    Jun 2011
    manchester uk
    Default bump
    anyone??
    further to last,
    the light always goes out after a few hundred yards of driving from a cold start however stays on if theengine is warm???
    any ideas??, no other fault is showing on ecu scan other tha P0650
    Simon
    Full Member Big Sig's Avatar
    Free
    Jun 2011
    manchester uk
    Default post not staying on "new posts"
    Hi i am new to the site and can anyone tell me why my posts do not stay on the new posts page, they seem to drop off quickly before anyone can reply, or is it one of those things you need to pay subscription for.
    thanks
    Simon
    11 Post(s)
    Probably because other new posts come along and push your post down the pecking order. If however someone replies to your post, it will bump it back up the list again.
    Makes no difference whether you're a new member, regular member, or fully paid up member.
    There is no conspiracy going on.
    Aug 2011
    Paris
    Hi,
    I have an Vectra GTS 2.2 DTI and the same problem like you : error code P0650 and the LED of Check Engine don't turn on...
    I have unmount the instrument panel and unplug it...
    The member 'fm-online' said "Turned out to be a dry joint on the speedo pcb connector" but how to open the instrument panel and find this "joint" ?
    Where can i find ā tutorial ?
    Thanks a lot,
    Cheers.
    PS : Sorry for my poor english...
    Jun 2011
    manchester uk
    Default Not solved
    Hi
    i have not solved this yet either, i did remove the speedo clocks ect and re-atatched the connector but didnt open it up ect, anyone else on here having the same issue of p650 as the only code with no mil light causing car and spanner light.
    Simon
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Could be a loose earth somewhere.
    Jun 2011
    manchester uk
    Default Earth
    Could be but the million dollar question is where the loose earth may be lol!!
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah I no wasn't much help lol. A would start at dash board lol.
    But possibly go onto astra owners network an speak to *****
    He might be able to help
  1. Replies: 2
    Last Post: 24th June 2012, 02:11
  2. P0621 - Generator Lamp "L" Control Circuit Malfunction
    By danielk in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2012, 20:57
  3. p0480 fault code cooling fan 1 circuit malfunction
    By Miketwinny in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 22:31
  4. mil control circuit malfunction code PO650 ( no dash warning light on car)
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 23:08
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
p0650 opel vectra C
p0650 vauxhall fault code
p0650 opel
p0650 opel corsa c
Opel P0650-C
p0650-04 vectra c
opel p0650
p0650 vauxhall
vauxhall p0650
vectra 1.9 cdti engine code 0650
p0650 opel signum
vectra c malfunction indicator mi
Opel DTC P0650-04
cod eroare opel p0650vectra c p0650 malfunction indicatorp0650 opel vectravectra c malfunction indicatorp0650-04cod eroare P0650 opel vectrafault code on vauxhallpo650p0650 vauxhall faultp0650 fault code0650 vikanoodiopel signum p0650po650-04 kode opel
