Results 1 to 10 of 19
Thread: Disable Fog Light Bulb Warning
    Jul 2011
    Scotland
    Default Disable Fog Light Bulb Warning
    Hi guys,
    My work has a Vectra pool car which had an altercation with a tree during the high winds a few months back. The front bumper was quite badly damaged and has since been replaced with a used unit off of eBay.
    The new bumper is on and the car is looking presentable again, however, when fitting, I realised it wasn't the same as the bumper I originally had and I now have no way of fitting the fog lights back in.
    Being a pool car, I this is no huge issue and we can happily live without these, but I now have the annoying dash board warning advising me that there is a bulb out in a fog light ... little does it know!!
    Can you guys advise if it is possible to disable this at all? Is it just case of removing the fuse for the front fogs?
    Thanks,
    Stephen
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    i may be wrong .
    but if you have the black coloured plastic blanks on the new bumper .
    can you not just pop them out and insert the old black plastick " with " the fog lights already in fixing the dash warning problem .
    maybe they are bonded or even screwed on ,
    i am sure someone will come on here and tell us .
    i hope you get it sorted .
    Jul 2011
    Scotland
    Thanks for the reply.
    You thought the same as me, however, it turns out the bumper with fog lights has different sized inserts and my inserts do not fit in this bumper.
    Full Member Big Sig's Avatar
    If you still have the wiring can you not just put some bulbs into the connectors etc?
    Dec 2010
    Timisoara
    add pictures with the new and old bumper so we can make an idea. I assume you had a gts bumper and now have the stander one.
    8 Post(s)
    Jul 2011
    Scotland
    Quote Originally Posted by cornel18 View Post
    I have no idea what bumper I had originally. I still have it though and will try and get some pictures of both if required ... or at least so no one else makes the same mistake!!
    I like this plan and will look into this.
    Will let you know how I get on, thanks
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    But if you want.. yes the front fogligts can be disabled if you want..
    Jul 2011
    Scotland
    Quote Originally Posted by kenp View Post
    Hi Ken,
    Thanks for the response.
    Can you advise how to do this?
    Stephen
    Engine : 2.2 Direct
    The bulb check is in the Screen and intrument
    The foglight is self is in the Instrument and the UEC and BCM
  1. Bulb Warning Light...
    By Ross-SRi in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 20:49
  2. Bulb warning light
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2011, 19:03
  3. Bulb warning light
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 00:13
  4. Bulb Warning Light
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 16:10
  5. Bulb warning light
    By mike12 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 22:23
vectra disable bulb warning light
vectra c bulb warning light on displey unit
vectra c fog light bulb warning on dashboard
vectra front fog light warning
can vectra c bulb checker be disabled
how do I turn you off my bulb warning light on my vectra
vectra c bulb warning light for front fogs
check fog light vauxhall vectra turn off
vauxhall vectra fog light check switch off
vectra warning lights bulb
how to fit a fog light to a vauxhall vetra
vauxhall bulb check disable
vectra c disable bulb warning light
vauxhall signum clear fog lamp message
