Results 1 to 10 of 11
Thread: Fitting Rear Coil Springs
    Jun 2011
    Fife
    Default Fitting Rear Coil Springs
    Need to replace a snapped rear coil spring, if anyone has done it did you need to remove the shock or was it enough to remove the rear wishbone to hub bolt, did that give enough clearance to get the spring out?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you looked in the how2 section?
    To answer your question, not you don't need to remove the shock. When you remove the lower arm stick a bar into it and push down
    Jun 2011
    Fife
    Yes, looked thru all 11 pages of the how to's maybe i missed it but defo looked, its a must before I post but nothing for rear springs,
    Cheers for the answer tho
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Jun 2011
    Fife
    Good find, i must have been speed reading and just read the beginning, I will go and do my lines
    lincolnshire
    probably the easiest rear coils to change on a car that i know of !? undo shocker bolt , pry down swap spring and rubber seats , raise suspension up to meet shocker , put bolt back in ! takes so little time you wont even need a tea break ! ;-)
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by bembo449 View Post
    Remember it's not the shocker bolt. Undoing the shocker does nothing whatsoever
    Regular Member Jezzy's Avatar
    S.E
    Except give you a shock when you drive off with the bolt still undone...
    Feb 2011
    lincolnshire,sleaford
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    do you need any spring commpressors to replace a rear spring then ?or is it just undo one bolt?
    Jun 2011
    manchester uk
    Default Spring compressor
    No you dont need a compressor for the rear springs just make sure you place a jack under the control arm to slowly lower the arm.
  1. Lesj÷fors Rear Coil Springs
    By leeds vectra in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2012, 23:13
  2. Anybody willing to fit front and rear coil springs for me?
    By peelmeister in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2011, 17:54
  3. Rear Coil Springs for Towing
    By 798EAT in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 21:03
  4. 2.0T Rear coil springs
    By r.bailey63 in forum Suspension, Wheels & Brakes
    Last Post: 21st March 2010, 20:44
  5. Rear Coil Springs. 2.0 DTi 2003
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 12th April 2009, 21:32
vauxhall vectra rear coil spring replacement
vectra c rear spring removal
vectra c rear spring change
vectra c rear coil spring replacement
vectra-c.com changing rear springs
vectra c rear springs
vectra-c.com rear springs
vectra c spring replacement
vectra c rear coil spring removal
changing rear springs on vectra c modelvectra 07 diesel how to fit spring to rear of vehiclevectra rear spring replacementreplace vectra c rear springshttps:www.vectra-c.comforumshowthread.php141595-Fitting-Rear-Coil-Springschange rear springs vectra crear coil springs vauxhall vectrahow to change vectra c rear coil springshow to change rear springs on vectra cvectra c rear coil springsvectra c rear springhow to change rear spring vectra cvectra c rear spring replacementestamated time for changingrear springon vauxhall vectraremove rear coil spring corsa cback spring for vauxhall vectra
