Thread: GSi clutch
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default GSi clutch
    Soon as some money comes available i'm gonna have to get my clutch done as when making a quick getaway it's deceided to start to slip.
    Now i hear that the early GSi's with 308m front discs do not have a DMF but cars with 314mm discs do, would i need to have this changed at the same time or is it not as bad as other Veccies that are prone to go though their DMF's.
    Cheers.
    Full Member Big Sig's Avatar
    302's
    lincolnshire
    if its a none DMF clutch then it will be cheaper than one with thats for sure and yes ! if it has one the whole thing has to be changed
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by bembo449 View Post
    Why does it HAVE to be changed? If the dmf isn't rattling or causing any problems then just fit the clutch.
    You don't change brake discs just because the pads are worn and the clutch is no different. Change things because they need changed, no point fitting a new dmf if the old one is in good order
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
