Thread: Vectra cdti 150 power loss and miss fire help please
    Mar 2011
    Stamford
    Default Vectra cdti 150 power loss and miss fire help please
    hi about three months ago i brought a 56 plate 90,000 cdti 150 estate that after three weeks broke down and ive only just got running again after fitting the following parts:
    Diesel pump (Recon unit)
    4 recon injectors (been reprogramed)
    New DPF
    New Turbo
    New Inlet manifold
    New pressure reg
    New Pressure sensor
    3rd injector wiring
    New fuel Filter
    Basicy i took it to the local garage and it was diagnosed with low fuel pressure. Kept coming up with pressure reg fault, the pump died and one of the injectors was stuck open so changed them all.
    My problem is it still has a missfire at tick over and has little power and after a mile or less eml light comes on and struggles to do 60mph goes into limp mode! turn engine off while driving and back on it goes and then seconds later comes back on.
    Really need help as the car has nearly broke me and having to do my self as can no longer afford garage costs anymore.
    would an egr cause this ive took it to bits and cleaned but no difference?
    ive also cleaned the boost sensor.
    any help would greatfully be recived
    Chris
    Mar 2011
    Stamford
    Anybody???
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Morning,
    Have you had the car on any form of diagnostics?
    Or do any of the parts you have had fitted need mapping to the car (via Tech-2)?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Looking at the list of things you have replaced and noticing that you will still have the old EGR valve on this would be my first port of call for sure - they should be at least cleaned with a new manifold fitted.
    Quickest method would be to blank it temporarily and see if this sorts the issues, if it does then you'll know what it is and can either replace/clean etc.
    Mar 2011
    Stamford
    Cheers I've ordered a new one so will try it and update you all. Thanks for the replys.
    All parts have been programmed apart from dpf as it failed half way through as elm light came on. Need to sort before it will regen correctly.
  1. Miss fire at 1500rpm on my 120 cdti
    By rob10 in forum Diesel Engine related
    Last Post: 29th June 2013, 23:37
  2. Vectra sxi 1.8 16v won't rev. Miss fire. Helpp
    By Arran1993 in forum Engine & Drivetrain
    Last Post: 31st October 2012, 19:49
  3. Power Loss Vectra V6 3.0 CDTI
    By renwich in forum Y & Z30DT Specific
    Last Post: 7th September 2011, 22:52
  4. Vectra CDTi 150 - Loss of Power
    By Chappers. in forum Engine & Drivetrain
    Last Post: 4th January 2011, 23:37
  5. loss of power miss fire
    By basemanlee in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 20:41
